Need Screwdriver help
Old Jan 12, 2011 | 06:30 PM
steelblitzkrieg's Avatar
DTR Detective
Looking for anyone who knows a tool company who may sell something similar.
#2 Phillips with a 27" or longer shaft.
Thanks in advance.
Old Jan 12, 2011 | 06:55 PM
kthiemann's Avatar
I think you'll end up with either Snap-on or Mac, I can't think of anybody else that might have one that long, although you might give Sears a try just for grins.
Old Jan 12, 2011 | 06:59 PM
madhat's Avatar
Administrator/Jarhead
I found a 22" on harbor freight.
When I need something that long, I just use a bit and a 1/4 inch ratchet with extensions.
Old Jan 12, 2011 | 07:01 PM
befitz's Avatar
Snap-on makes a soft-grip ratcheting screwdriver. You can pull the shaft
out and put any length 1/4" extension into the handle, then put the shaft
on the end of the extension. Have to use a Snap-on or other small diameter
extension, the cheap extensions are to big to go in the screwdriver handle.
These screwdrivers are about $60.
Old Jan 12, 2011 | 07:16 PM
befitz's Avatar
I agree with Madhat. I checked the Snap-on site. The handle alone is
$49.95, and the shank is $16 and change. Plus shipping and tax.
Old Jan 13, 2011 | 10:41 AM
DTR Detective
Thanks guys.
One of the appliances we work on, the oven door handle comes loose and the screw is only accessed from the bottom of the door and the screw is at the top of the door. Gotta love engineers/designers.
We have one 27" #2 Phillips that we must have picked up at a flea market or something over a decade ago. Can't remember, and one of my other techs wants one for himself.
Old Jan 13, 2011 | 10:59 AM
Blake Clark's Avatar
Here is a #3 at 24"
http://www.grainger.com/Grainger/scr.../N-98oZ1z0ldv5
Not an exact match, but close.
Old Jan 13, 2011 | 11:10 AM
Totallyrad's Avatar
Go to a cheap tool store like Harbor Freight or a flea market. Buy a couple drill bit extensions with set screw locks in the female ends. They'll be hex and the female end should be around 1/4". Just insert a hex phillips and tighten the set screws. I saw some of the extensions last week a tool flea market for $2.50 each for a 12" extension.
Come to think of it, you could get that stuff at Lowe's or Home Depot.
Old Jan 13, 2011 | 11:28 AM
DTR Detective
Too thick to fit through the access hole. But I was just informed that 24" will work, which is great since Blake posted the Grainger option.
Old Jan 13, 2011 | 11:31 AM
Totallyrad's Avatar
Here you go. Click on the link and scroll down, extensions to 72". If you're searching locally, they're also known as spade bit extensions. About $23 plus extras.
http://www.telephoneparts.com/index....ols/Drill+Bits
Old Jan 13, 2011 | 11:33 AM
Totallyrad's Avatar
OK, scratch my last post.
Old Jan 13, 2011 | 12:19 PM
wyododge's Avatar
You could cut the shaft of a screw driver you already have, or buy one with the right tip and grip you like, and weld in an extension... If you ground it smooth you could paint the extension with liquid plastic. With the chaft painted it would protect you from touching any contacts or bare wires and protect you from a short.
You could also own it today, if you can weld or know someone who can.
Probably only cost a few of bucks.
Might even be able to sell a few to recoupe the cost.
Old Jan 13, 2011 | 12:28 PM
turbodiesel101's Avatar
i was going to say its just vodka and orange juice.... buuut what may work is the ratcheting screw drivers with the multi tip. get a reaaaal long extension and then you can pick the tip you want.
STate
Jan 2, 2010 12:44 AM
Mexstan
Oct 13, 2009 03:13 PM
Supertrucker78
May 28, 2007 08:10 PM
natstayl
Aug 18, 2005 11:12 PM
