Any ides on the name of this electrical plug?
Any ides on the name of this electrical plug? and if it's possiblr to get a extension cord for this type of plug?
Check to see if it could be 220V. Sorry, don't know the name for that plug.
That's a three prong dedicated plug. It is used to run higher voltage to an item like a welder or such and can also be used to signify a non GFCI'd leg of a run, like for a freezer or space heater.
Use a multimeter to check for output on that circuit before you plug a 110V item into it!
The recieptle is a NEMA 6-20 T Slot 20 amp 250 volt.
And the plug is a NEMA 6-15 it is a 15-amp 250 volt.
The plug is also commonly known as a Chinaman for obvious reasons.
Here is a NEMA Chart of some of the different configurations.
http://www.stayonline.com/reference-...ght-blade.aspx
http://images.search.yahoo.com/searc...&va=nema+chart
You should be able to get an extension cord at Home Depot or get some 10 gauge sjo and install your own ends just make sure to observe the color code on both ends.
What is it used for, an air compressor or other machinery?
Odd to be in the same box as with the 120 volt devices.
Jim
Jim
You guys are way too honest, friendly and helpful! The correct answer would be, "Plug a small 110 volt item, preferably something with a motor, into the plug and turn it on. Make sure you have someone else with you to record it on video so you can watch it later for reference. Posts your results on You Tube so we can see how you make out."
It can be confusing when you are looking at the plug or the recieptle because it will be a mirror image, luckily they are all made a bit different so the wrong plug cannot be inserted.
These have also been used on low voltage D.C. on off grid applications where no A.C. is anywhere present.
I have seen people cut and twist the blades of plugs trying to make them fit usually with costly and smoking results.
Jim
The old Smoke Test..
On construction sites sometimes the 120 volt tap has less than 90-volts when all of the other guys have their saws running. if you don't have your own buck/boost transformer to correct the voltage.
We have run skill saws off the 240-volt recieptle of the power pole with about 800' of extension cord in between for voltage drop, the saws do run a bit hotter.
Of course you have to make your own pigtails.
Jim
for the male or female plug. The arrangement of the color of each wire is
made to connect the wire to each terminal without having to cross the
wire at the male or female connector. I hope someone can word this
better. Jim?
Jim nailed it. The receptical is a 20 amp 250 volt. The plug is a 15 amp 250 volt. These are the common plug/receptical used on our 240 volt system. The 20 amp receptical will accept both a 20 amp plug and a 15 amp plug. A 125 volt plug and receptical will have the horizontal and vertical blades reversed to prevent you from accidently preforming a smoke test.
If you put plugs on sjo, there can be a "better" end to use
better. Jim?
better. Jim?
PS did anyone else notice that nice custom plate in the mulberry cover?
You could have mistaken it for a NEMA 5-20 which is a 125 volt device.
Jim
Jim
This is typical example of an unexperenced homeowner asking the Home Depot employee for advice on how to wire the recieptle.
Most of them but not all know just enough to get someone killed.
People are always asking me how to do something in every department, not just electrical.
This recieptle is usually used on light stationary appliances like air conditioners.
Anything portable I always use a Twistlock, for my welder I use a 30~amp dryer recieptle and mating plug cap.
Jim
