Need to paint over rust, help please.
Old Oct 17, 2007 | 03:19 PM
krawler-N-tow's Avatar
I don't feel right about doing this but I don't see how I can remove all the rust. I'll try to make this short.
I bought a well constructed HD trailer that I got at a good deal because the builder ran out of time and funds to "finsh it". All it really needs is to be wired, lights mounted, tagged and the biggie-painted. The PO had a tarp over it but as you can figure it still accumulated surface rust, everywhere.
Any ideahs on what to use/ how to go about painting something like this? Sanding/sandblasting is pretty much out of the question here, too big and too much detail to the trailer.
Old Oct 17, 2007 | 03:21 PM
Deezel Nate's Avatar
Wire wheel or sandblast. Sorry you need to remove what you can or the paint will just be a waste of $$.
Old Oct 17, 2007 | 04:19 PM
t-boe's Avatar
POR 15 or Eastwood's Rust Encapsulator. It keeps the rust from spreading and you can paint over it. Preferably, I would remove it all with a wire wheel or take to a sandblaster and have it removed.
Old Oct 17, 2007 | 04:37 PM
FiverBob's Avatar
Sandblast all you can, then brush on a coat of OSPHO. Allow to dry in a very dry environment for 24 hours, then apply a water proof undercoating, then final finish. Ospho will chemically treat the rust removing the oxide leaving a surface ready for paint. It is used in body shops.
Old Oct 17, 2007 | 06:22 PM
Thanks for the replies. I promise you would give yourself a laugh if you saw this trailer after saying "use a wire wheel". I have a wire wheel and I'm far from a lazy man but this is out of the question- I don't have a month to spend on this Although I do plan on giving it a "light" sanding to get the loose stuff off. I have been looking at this stuff after talking with a friend that customizes frames for big rigs http://www.magnetpaints.com/underbody.asp
cheff
Feb 25, 2006 12:19 PM
thatguy
Aug 10, 2005 09:27 PM
steelydan
13
Feb 4, 2005 08:21 AM
bigfoot
Aug 14, 2004 02:22 PM
Dodgezilla
Jun 9, 2003 04:33 AM
