Need help with wifes 04 Chevy TrailBlazer
This winter my wifes 04 TrailBlazer has developed a sever wine in the frontend and realy dont like going in and out of 4wd. It gets all bound up and you can feel it load up then jump and come loose then repeat while going down the road almost like someone changed the gear ratio over last summer. It feels like our trucks do if you put it in 4wd and turn on dry pavement. only it does it while going straight. Yesterday we took it to church and had to drive in 4wd there and home(8miles one way). After getting home and parking it in the garage I could smell hot gear oil. After changing cloths i went back out and started feeling around and discovered the front diff was hotter than I thought it should be. It is almost intergrated into the oil pan though so it could have been engine heat but I dont know. I am gona go out now and check the air preasure in all the tires just to be sure that one isent low and causing the diamater of the tire to be diferent than the others. Has anyone ever ran into such a problem with there trailblazers or know of a good forum to go post this isue on.
Ya we did replace a tire when a nail went threw the sidewall. The replacement is the same size but a differnt tire. I measured the tire though and its within a 32nd of the same diamater as the rest. I have been thingking that that may be the isue as well but it measures so close to teh same that I have a hard time baliving it is the isue. I realy dont wana replace the entire set of tires just to find out that they where not the problem. I may though. The tires that are on it are the absolute worst snow tire ever made and we have abought twice our anual average snow fall this year.
The vacuum systems that engage the front end get to be problematic, especially in the cold, and keep the front end engaged unknowingly even without the t-case engaging. That'll help wear out the engaging/shift mechanism in the axle housing and may have been going on long enuff to cook a bearing in the diff?
I was a little worried abought a bearing but if it was a bearing wouldent it wine even in 2wd. The CV shafts are always turning so the bearings are as well. The only bearing that wouldent be turning all the time is the pinion bearing.
The cv shafts will always turn with the wheels. A motor on the transfer case actuates the central axle disconnect to engage the front end. Usually it's a vacuum system. The vacuum line to the front can go bad, leak, get plugged, and even cold weather can interfere. If you didn't burn yourself, the bearings probably aren't cooked, but probably working harder than they should be, since it's not intended to be a full time system.
I got an apointment to get it looked at sat morning at the Chevy dealer in the next town over. The local Chevy dealer is horible at diagnosing stuff. The last thing i brought them they wanted to replace a wheel hub and ABS wiring harnes because the ABS wire going to the hub was broke. They wanted around $700 to fix what turned out to be nothing more than a broken wire. That was on her 00 Grand Prix she used to have.
Personaly I hope it is just the oddball tire screwing with the system. She needs new tires anyway, or atleast ones that are better in the snow.
SuperGewl
Oct 1, 2003 11:45 PM
