need help(not to important) antonomous robot project
Old Aug 29, 2006 | 02:29 AM
H2SRDMB's Avatar
so i deceided to get involved with a group to build an antonamous robot/vehicle! while planning we decieded to go with a tiny generator for power.
we grabbed some specs online and made some decisions. but now we find out the little honda EX-350 we liked is no longer made! so if anyone knows of any small generatos in the 350 watt range. ad removed let me know. all input is appreciated!
so far 8 hours of google has got me nowhere but asking here.
thanx again in advanced
Old Aug 29, 2006 | 03:17 PM
Begle1's Avatar
I want to make an autonomous robot... What's it for? Sounds like a project I'd like.
Can't you use an alternator?
Old Aug 29, 2006 | 03:30 PM
HappyGA's Avatar
hey Begle...
Did you know your turkey's neck is see thru?
I had robotics in high school, it was electrical, and was controlled with a 3 axis coordinate system.
Old Aug 29, 2006 | 03:33 PM
Begle1's Avatar
Originally Posted by HappyGA
hey Begle...
I, uh, reckon that I knew that...
Old Aug 29, 2006 | 04:06 PM
XLR8R's Avatar
we grabbed some specs online and made some decisions. but now we find out the little honda EX-350 we liked is no longer made! so if anyone knows of any small generatos in the 350 watt range. or happens to have a honda ex-350 they would like to sell let me know. all input is appreciated!
Why not use one of the new fuel cells for laptops?
Old Aug 30, 2006 | 02:02 AM
H2SRDMB's Avatar
look like thats what the new plan is going to be... but i just wanted a prefab allready complete package to drop in. plus the ex-350 could be modded to be 12volt110 only.
i beleive the competition is at
http://www.robogames.net/rules/magellan.shtml
just somthing my roommates and a few friends are doing to waste extra time!
your welcome to come over and help! but you might end up going home with something extra welded to your truck..
Old Aug 30, 2006 | 02:15 AM
Begle1's Avatar
Ummm...
The robot must not be constructed in such a way as to damage the environment or other robots. See "Safety" for other restrictions. No robot may weigh more than 50 pounds nor may it use an internal or external combustion engine. The robot must fit inside a 4’ x 4’ x 4’ cube for the entire duration of its run.
So, what's the generator for?
Old Aug 30, 2006 | 07:21 AM
Jim Lane's Avatar
Ummm...
That sounds fun but a bummer it can't destroy things.
What kind and how much power is needed? will the traction motors and electronics probably need to be seperate?
Maybe lithium ion packs.
You could use the exploding laptop batteries from DELL.
Old Aug 30, 2006 | 11:08 AM
XLR8R's Avatar
That'd definitely destroy the robots and environment!
Old Aug 30, 2006 | 11:20 AM
Begle1's Avatar
You could probably get a grip of litium-ion batteries for dirt cheap, though. It's actually a pretty good idea...
Old Aug 31, 2006 | 02:27 AM
H2SRDMB's Avatar
Ummm...
hahaha you got me.... i didnt read the rules . i was fallowing orders. umm wich reminds me. (mumbles somthing to self) ok i guess ill slap my roommate with that one and see what happens!
unless they changed somthing in the last week or two. then that would really suck!
thanx for bringing thhat to my attention! but it is nice to see our site is 2nd when you google robomagellan!
Old Aug 31, 2006 | 09:24 AM
XLR8R's Avatar
Begle1 - what gives?
... your infamy is withering on the vine.
Old Sep 1, 2006 | 12:22 AM
H2SRDMB's Avatar
solution...
so we got some new solutions. talked to the people at the contest. and they will not let a gas/hybrid into the competition , so we did some research and deceided to go with a electric scooter setup.
so begle, whatcha doing this weekend?
Old Sep 1, 2006 | 04:53 AM
Jim Lane's Avatar
I was wondering what you were going to use in the motive department,
I have one of those off road style wagons I bought for my daughter a few years back and I got tired of pulling it so I designed and built a matching pusher trailer that push the wagon as you walked along in front of it.
I used an electric wheelchair (Invicare the kind paraplegic people drive) gear motor through a drive chain and sprocket I bought from a go-kart company to the rear wheels. It is controlled with a PWM controller and a small hand held throttle. The motor has enough torque to break the drive chain if you are not careful.
It is powered from 24 volts 2-12 volt gel cells and will run 6 hours continuous before I have to recharge.
You could use 2 gear motors left and right side direct coupled to each wheel. They are meant to use a Curtis controller but I have a source for a company that builds PWM controllers for robotics that are a lot cheaper.
Maybe you could use the brains from a Furby and teach it to navigate the course.
This the company C&H Surplus
I got the motors from. I always leave there with stuff I never knew I needed.
http://www.candhsales.biz/CandH/index.htm
These are the motors, about 2/3 down the page.
http://www.candhsales.biz/cgi-bin/sh.../page=DCGM.htm
Stock #DCGM2103RH
Jim
Old Sep 1, 2006 | 10:58 AM
Begle1's Avatar
No thanks, I got enough on my plate this weekend... Veggie-oil set-up and all...
Do you know how you're going to navigate anything? That's the hard part...
Mechanically, you just need something with really good ground-clearance that won't high-tail itself...
whiskeyrichard
Mar 31, 2009 03:31 PM
cbrahs
Aug 20, 2008 10:54 PM
Bad Ramer Jamer
Jul 26, 2007 02:36 AM
Tuffram
Mar 30, 2005 09:02 PM
