Moving Concrete
Old Oct 15, 2018 | 11:26 AM
bannerd's Avatar
Moving Concrete
Hey all, need to get some footers poured and our new home is on a small hill. I have a case 580 that I could use to move the concrete but going up a sand slope would be a challenge. Pump trucks are really expensive but I will need one for the ICF pour. I was hoping to do the footers but man. Maybe I just need to gravel the entire thing and smooth it out? Thoughts or options?
Old Oct 20, 2018 | 10:13 AM
SIXSLUG's Avatar
It wouldn't hurt to build an accessway to the site. You'll have lumber and other deliveries coming next. We pump hundreds of cyds every year. See if your ready mix cupplier can provide a pea mix design that you could use a grout pump with, they are a lot smaller and should be considerably cheaper than a boom, and a 3" hose is a lot easier to drag around.....
Old Oct 23, 2018 | 06:08 AM
bannerd's Avatar
Well I wonder if a grout pump will work, the mix is suppose to be a slope of 7-9 because of the nexcem wood/clay material. According to the technical document anyway.
Old Nov 3, 2018 | 12:05 PM
SIXSLUG's Avatar
Depending on your regions aggregate quality, another sack of cement per cyd should get you higher strength and a slipperier mix for the smaller hose.....
04ctd
May 18, 2005 12:18 AM
quantrill88
Dec 3, 2004 11:57 PM
Dave65
Aug 31, 2004 09:11 PM
Dave65
May 29, 2004 08:49 PM
DarrellB
May 5, 2003 10:47 PM
