??? Mixing Bondo ???
I have a what looks to be gallon can of Bondo-Hair body-filler.
The directions say to mix 1/4 can of Bondo to 1/4 tube of hardener.
I would like to break this down into smaller amounts.
If I have one cup of Bondo, how many drops of hardener will it take??
Also, I noticed two different hardeners, at the parts store, plain and RED; what is the difference??
Thanks.
Thanks.
I used the red.
mix a blob about the size of your bondo paddle with pea sized drop of the red stuff. mix this together. It should turn a light pink. and will harden in about 10 minutes. Only mix what you can work with.
It's good that it isn't.
I am using the HAIR stuff.
It is deep blue-green, right out of the can.
The creme hardener, that was attached to the can, is red.
I have successfully (I hope) mixed a few rations, as per you guys advice.
We will see how it turns out.
I thought gooey old fiber roofing tar was a mess to deal with; but, this stuff takes the medal.
