Just a question, and probably gonna get moved elsewhere
Old Dec 30, 2003 | 07:58 PM
shortround's Avatar
From: In the middle of Weather Dry Creek Farm in Avilla, Arkansas
Question here for all you old hot rodders.
We would paint the pipes down each side of the duals, not far after they came out of the manifold/headers. Then run it for a while and look at the paint. Where it was burned off the most was where we put the H/X/equalizer pipe. Keep that thought in mind.
Had a chance to play with the exhaust system a bit back and did. I removed everything from the resonator back and replaced it with a 3” inlet, dual 2 1/2“ outlet Borla muffler. Both outlets exit on the right side just behind the rear wheel.
When I was putting shocks on the truck, I noticed a spot just in front of the muffler that appeared burned/discolored/a bunch different. It has to be a heat build up of sorts, which tells me what’s going in ain’t coming out fast enough or what is the significance of this sign from the almighty Cummins? The truck runs good, except for, what seems like a bit of a choking down of the turbo at rpms over 2200.
I know; Call Rip Rook. He has the answer!!!!!!
Could it be that the beast has the same problem that we sometimes have in electronics; resonance? As in cavity type.
How about some ideas(besides, I need a real good excuse to put a GOOD exhaust system on the truck)?
duetothewifeactingunnaturalI'vegottosayShortround out
Old Dec 31, 2003 | 08:04 AM
JKE's Avatar
JKE
How long have you had that muff on the truck?
modified03
Feb 11, 2009 03:28 PM
kas83
Mar 11, 2008 12:13 PM
NHRedneck
15
Dec 8, 2006 09:02 AM
Dodgezilla
Dec 3, 2004 09:08 PM
