Jeep help!
Old Jun 25, 2009 | 05:54 PM
Mattster's Avatar
Jeep help!
So I'm driving around today, running fine as usual. Getting close to my home and all the sudden I loose power and I hear metallic pieces braking up, I'm like crap I blew a rod. Don't see anything bouncing in the rear view mirror and it still running just very rough, pull over shut it off, pop the hood look around, don't see anything unusual, no oil leaking anywhere or connecting rods sticking out of the side of the engine.
Look from underneath looked fine. Started the engine again, very rough surges from almost 0rpm to 750. heard a bit of metal fly around somewhere but stopped, since I was like 1/2 mile from home I limped it the rest of the way, took quite awhile at very slow pace, any throttle would make it almost die and didn't improve speed.
Last few weeks or so I have suspected the fuel injectors starting to go bad but haven't had time to get new ones just had poor fuel economy. Exhaust is clear not black like its running rich when its running right now, before this incident a friend said when I really got on it there was a small puff of black smoke, possibly due to the TPS being out of adjustment? Anyways, what should I look for when I got outside again, letting it cool down as its still very hot. If I didn't throw a rod is it possibly the flexplate broke up as it was back of the engine area, but would it started ok so I imagine the teeth on it aren't too bad. Also had to put it in 4Lo to get it to crawl up my driveway which is dirt/gravel because 700rpm wasn't enough to make it up in 2Hi.
Update: Checked the Oil and Coolant they are fine. Spark plugs were pretty nasty so I cleaned the 4 I could reach easy while the jeep is parked on a slope. Looked underneath some more and noticed the crank sensor bolt is missing and probably fell on the flexplate hence the noise I heard, but the sensor is still close enough to the flexplate it gets a signal and the engine starts just very rough, so that may be my problem, might be worse.
Old Jun 25, 2009 | 09:01 PM
badme's Avatar
bolt flying around or a broken flex plate will screw up the crank sensor and make your jeep run as described.
Mr. Jimmy
Feb 4, 2007 09:53 AM
loid mongol
May 2, 2006 12:33 PM
Wilson
Oct 7, 2005 10:43 PM
SjLingenfelter
Nov 7, 2003 03:44 PM
bkay
Feb 18, 2003 10:19 AM
