IH 300-Utility ?'s
IH 300-Utility ?'s
I've got my buddy's 300U split in half in my shop. 2nd gear on the counter shaft is missing 3 teeth and the shift fork for 4-5 is broken beyond repair. Anybody know a good yard to call for used International parts? Already called the local dealer with the part number, but it's obsolete. I plan on putting a post up on ytmag.com as well. I'd even consider buying a parts tractor if there was one close enough.
Thanks
Thanks
I've used this place before . They have 800 # so you got nothing to loose.
http://www.gaptractor.com/
Give Bates a try, they are located in Bourbon IN. They carry about anything you might need for a Farmall or IH tractor.
http://www.batescorp.com/
If you don't see the parts you need on there online catolouge give them a call or email. They have a ton of parts in their warehouse. My dad used them to get some hard to find widefront parts for his M.
Thanks for all the replies fellas
I'm chasing down a couple leads now. Found a used gear for $80. Does that seem in line? I guess when it comes to hard to find parts, it's a sellers market. On a side note, I've never been this deep into an older tractor--pretty dang cool
....and heavy
....and heavy
http://worthingtonagparts.com/about/locations.aspx
The St Johns Michigan location has ACRES of tractor bodies. It's a graveyard for combines, but there are others too.
guzzirider
Dec 29, 2003 11:28 PM
