I need to find F or G rated tires
I'm gonna need new tires for my truck come spring I'm sure of it. Had these ones on here that I bought in March or so. General grabber AT2, very good tires but the ones on the back are about gone now. I'm guessing about 30-35k on them which is good. They are E rated but looking for something heavier, F or G rated. Figure if I get something heavier the tires will last longer than a year....maybe.
The truck is loaded all the time, weighs in at almost 10k, all the time. I know folks are saying buy 19.5's at this point, I cannot afford adapters, wheels and tires for 19.5's so out of the question.
I've checked a few tire places online and none sell F or G rated, only go up to E's.
Anybody know of online stores that sell these? Size is 235/85/16, prefer mud and snow but thinking that choices will be limited and might only be able to get highway tread.
thanks for any info!
Shawn
Shawn
I don't know of anyone making a f or g rated 16" tire, if they did it would surpass the weight rating of the wheels and/or vehicle so you will probably need to go to 19.5 for that. What conditions are you driving in, if it's mostly on road driving then decent e rated tires should last a lot longer than 35K. I've seen BFG a/t's go almost 50K with about half of that being on ranch roads.
This pdf contains a reference to a load range (F) tire on page 7. The manufacturer is Goodyear. I don't know if they still build the tire.
http://hmcclub.homestead.com/Goodyea...oad_Charts.pdf
This is for a Load range (F) bias ply trailer tire.
http://www.sturdybuiltonline.com/LT7...ity_p_113.html
This is for (F) and (G) rated tires.
http://shop.easternmarine.com/index....categoryID=558
Here's the search link.
http://www.google.com/search?q=load+...x=&startPage=1
My Goodyear E's went 58,000 before replacement. Most of the miles were towing with the truck weight being 8240 and the pin weight 3250. They still had rubber but were cracking - - Goodyear worked with me on crediting back for unused tire wear for five of the tires even at that many miles.
Not even sure what the General's I have on the truck are rated at mileage wise. They are E's but it's a welding rig so maybe more than the General can handle. Might have to spend a few more dollars on some goodyears or god forbid....Michelins
Most "F" tires require around 95# pressure to achieve their load rating. How much pressure will your rims and stems handle? And, make sure when getting into these grade tires you don't end up with a tire designed for a trailer - - look at the designations very carefully. You DON'T want trailer tires on your truck. They are much stiffer sidewalls and will ride like a - - well - - a truck. DUH ha ha. Also, they will not hold corners as well due to they tread pattern.
Bob
Bob
I just checked where I got these tires and they are supposed to be 60k tires. Wow! Time to start digging around in my receipt folder. Hmmm, did I send in the warranty info???
Maybe I can get new tires this year....one more deduction for the biz!!
05-29-2009 10:24 PM
duallydave
14
12-04-2007 09:51 AM
buddy26
47
01-04-2007 08:25 PM
sakisaki400
23
12-31-2006 10:17 PM
KATOOM
13
03-13-2005 09:41 PM
