How much weight?
Re:How much weight?
I run 500 pounds of cinder blocks in a frame I made that fits over the wheel wells so the weight is right on the axle and can't shift around. Sandbags get wet and freeze, then they slide around once they're a solid chunk. The best trick I've seen is to get a thick steel plate cut to fit around the wheelwells. A customer of mine did this, he's got a piece of 1/2 inch plate about 4 feet long and as wide as the bed notched to fit over the wheelwells. He says it weighs 800 pounds, he's got a loop welded on it so he can hoist it out with a crane. It's sweet because it takes up basically no room in the bed. He runs a structural steel shop and has access to steel and cranes, probably not something your average Joe can use.
Re:How much weight?
I have a fifth wheel ball in my bed but I could cut a hole around that and weld loops around the hole so its not taking up any other room that the ball wouldn't. I would make the plate a little smaller so its not soo heavy. I have an 855 John Deere Tractor with a bucket. I wonder how much weight that can lift? Also where am I gonna get a piece of steel that big?
Re:How much weight?
[quote author=Cumminsdude link=board=10;threadid=21210;start=0#msg199106 date=1066699698]
[/quote]
Beats me on both questions, like I said, the guy runs a structural steel fab shop. Sure beats my setup as far as space goes, though.
[/quote]
Re:How much weight?
Look into something else cumminsdude, unless you have alot of bucks to blow on steel. A 1/2 inch steel plate 4' x 8' is going to cost you hundreds of dollars. Your 855 will handle the weight without a problem though. We used ours to move 1400lb round bales when our Case was busy with other things. I like sand bags, but they are bulky.
Re:How much weight?
Thanks for all the help. I know but this is my first winter with her and I dont want to do anything to hurt her!!! Any other ideas are welcomed but so far sandbags sound the best. Maybe i'll build a frame for them. Thanks again.
Does anyone know if Home Depot has these sandbags? Or how about Tractor Supply? Just trying to find someone that has them.
Re:How much weight?
Cumminsdude- get good snow tires- the weight in the back will help you accelerate on slippery roads. Only a good tire will give you the chance to stop before the trouble hits you.
Also care for a good mount or tiedown for the ballast you use- wouldn't want that stuff going through your back.
Just my 2c
AlpineRAM
Just my 2c
AlpineRAM
Re:How much weight?
Very good Points. Thank you.
I bought Cooper Discovery M+S tires so I hope they will do. They will have to do because they cost me $600 and I can't afford anymore. Thanks again for the advice.
Re:How much weight?
Srigs has a very good point, but old habits die hard for me.
I use a steel plate 50" x 15" x 1 3/16" that I bolt down to the bed. It weighs about 250 lbs. I bought BFG AT KO's so I'm going to try it without the plate.
I used to use concrete patio blocks that I bolted down with a piece of angle iron across the front. I think the ones with rebar weigh about 70 lbs. each. It was in a Chevy 1/2 ton that didn't have enough jam to slide them back. :
BTW, mild steel weighs about 490 lbs per cu ft. A 4x8x1/2" sheet tips the scales at about 650 lbs.
Re:How much weight?
[quote author=tmiller24 link=board=10;threadid=21210;start=0#msg199073 date=1066697451]
Why don't we all just move in next to Hoss and never deal with snow again!
[/quote]
Hoss gets snow but not as often as CumminsDude would get.
[/quote]
Re:How much weight?
[/quote]
No....Hoss doesn't like that idea.
[/quote]
Re:How much weight?
[/quote]
HMM?? Hoss on a daily basis or snow for 2 months?? I think I'll take the snow.
;D
[/quote]
;D
Re:How much weight?
[quote author=berner link=board=10;threadid=21210;start=0#msg199224 date=1066741051]BTW, mild steel weighs about 490 lbs per cu ft. A 4x8x1/2" sheet tips the scales at about 650 lbs.
[/quote]
Unless I'm reading my steel manual wrong, 1/2" steel plate weighs 20.4 pounds per square foot. This means a 4x8x1/2" steel plate would weigh....wait a minute 652.8 pounds.....which is what you just said....so I don't know why I'm writing this anymore. :
My initial calculation was much higher than your 650 pounds so I was going to correct you....but now I suppose I should feel kind of silly and delete this. Oh well....more ammo for the Hossites. ;D
[/quote]
