How the heck do you catch Geckos?
Old Jul 20, 2010 | 08:31 PM
hotdram's Avatar
Have one running loose in the house. Not a big deal, don't mind 'em, they eat the bugs. The wife loves them (as she does all animals). In fact she has even named it and declared it as our pet. I however, would prefer if "Gecky" lived outside where he would have a much better diet of bugs to chose from. Those little buggers are fast, how do you catch 'em?
~Rob
Old Jul 20, 2010 | 08:48 PM
Rpainter's Avatar
shotgun..??
Old Jul 20, 2010 | 08:49 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
I used a straight coat hanger with a 2 lb test mono-filament noose on the end that you could slip over the head and pull tight from a distance. You have to move slow and carefully I tried roping em with my lasso and would have gotten the job done but my horse was TOO slow
Old Jul 20, 2010 | 08:56 PM
hotdram's Avatar
Originally Posted by Rpainter
shotgun..??
If I hadn't left my chokes at the sporting clays range, I might consider that
I was gonna dig a hole through the carpet/concrete and put a bunch of little toothpicks sticking straight up in the bottom and then cover the hole with a sheet of paper, kinda like a tiger trap, but your method sounds much easier
Old Jul 20, 2010 | 09:03 PM
Admin Team Leader
Actually I tried your method and put Curare on the toothpicks for added measure, unfortunately the Grandkid's hamster mysteriously disappeared and I had to remove the traps
This method might work well for cats that pee on your Bar B Que as well
AggieJustin's Avatar
Sounds like you need a live trap for geckos. None of my traps are built with screen door wire cages.
Myself, I usually use the "multi-spear" aka broom. Then again, they're easy to hit when they're frozen after hearing my wife's ear piercing scream when she sees one.
Old Jul 20, 2010 | 09:07 PM
Admin Team Leader
I hear ya there
At my place snakes will raise huge knots on my wife's forehead.... Apparently the mere sight of one will cause her to run headlong into or through any nearby walls
Old Jul 20, 2010 | 09:11 PM
Totallyrad's Avatar
You just need a box and some attractive wallpaper, he'll walk right in.
Old Jul 20, 2010 | 09:18 PM
Blake Clark's Avatar
Switch your car insurance to Allstate. He will then approach you and convince you to try Geico.
Take that opportunity to use the shotgun.
Old Jul 20, 2010 | 09:20 PM
hotdram's Avatar
Wow T-Rad, never seen that pattern at Lowes before. Might have to check Home Depot.
~Rob
Old Jul 20, 2010 | 09:23 PM
hotdram's Avatar
Might be on to something there Blake. But if I shot him, there wouldn't be much left to BBQ.
~Rob
Old Jul 20, 2010 | 09:26 PM
~Rob
Mmmm Good point.
Okay. Small martini's then. Get him good and drunk and that should slow him down...
Old Jul 20, 2010 | 09:34 PM
hotdram's Avatar
Hmm, I like where you are headed with this Blake. But I have an improvement to the plan. My reaction time is much better when I have been drinking. Might give that a shot.
~Rob
Old Jul 20, 2010 | 09:38 PM
Tacomaman87's Avatar
Fire Crackers And a few
Old Jul 20, 2010 | 10:09 PM
madhat's Avatar
Administrator/Jarhead
Sticky trap.
