how to fix loss of PSI in Evap System?
Old Mar 13, 2006 | 08:55 AM
04ctd's Avatar
Buddy has a Tacoma with the code "Vapor Cannister is cracked" or something - per dealer
regardless, it's prolly losing PSI in the Fuel Evap system, just like the code when you leave the cap off.
how can we check this to see if the hoses are good, besides soapy water?
is there a little PSI system to pressurize the Evap system and monitor the drop rate of PSI?
or am i off base?
1999 TOYOTA TACOMA V6 3.4 Liter FI
Vapor Canister
www.Toyotacheapparts.com has it for ~197 or so, 260 from dealer
__________________
Old Mar 13, 2006 | 09:21 AM
DmaxEter's Avatar
You pretty much have to use one of those smoke machines they have to check it with. Its a low pressure system. The machine fills the system with a thick white smoke and you just look for where ever its coming out. I dont work on cars, but it has been my experiance that when you are having this problem, espeacially on a newer vehicle, the gas cap it self is the most likley culprit. It may look ok, but it may be venting and causing the problem.
Old Mar 13, 2006 | 01:26 PM
tmleadr03's Avatar
or am i off base?
Vapor Canister
__________________
Yes there is a tool for that, but it is a very good idea that you dont go above 1 psi, this are somewhat fragile systems. But its basicly a hand pump that you can check to see if the systems leaks. Its the green capped (or should be) schrader valve under the hood. If anything leaks you need to replace.
justagoodolboy
Jun 19, 2006 04:16 PM
DRM
14
Jun 6, 2006 12:00 PM
jlipskoc
Sep 23, 2005 12:24 PM
Shovelhead
May 3, 2005 07:18 AM
