Home A/C question
Home A/C question
MY central a/c is on it's last leg....the condensor. My ? is are all 13 seer or all 14 seer ratings the same? Or is one brand better than another? One a/c man I spoke with said that the big names are no better than some of the lesser names and have the same parts in them. Can someone help me?
Thanks, Tony
Thanks, Tony
Two different a/c guys told me the same thing. Parts are all about the same. So for me, that means looking for the best deal on price, and who has the best warranty. And of course looking into the history of whoever is doing the install, to see if people are happy with them or not.
I work for an a/c company in san antonio all i install is carrier and theyre great. Make sure to go with one with puron refridgerant r410-a the frion-r-22 systems are gonna be really expensive to maintain because they are doin away with r22 and are gonna stop making it which will make the price more than quadruple.
Thanks, Tony
Thanks, Tony
You might want to look at higher SEER ratings than 13. 13 is kind of the standard unit installed in new houses. There are units available up to SEER 19. Higher the SEER the lower the cost to operate - but the more expensive it is. But, saving 1/3 of your cooling bill each month can help pay for the upgrade.
Hal
Hal
Hal
Can someone clear this up for me?
Thanks, Tony
Yes that is something I need to look into. One thing I need to check on is the inside unit....whatever that is called is an 80/20 efficency, and I think I can only go so high on the seer rating without changing out the inside part also.
Thanks, Tony
Thanks, Tony
When I changed out my 13SEER system for a SEER 19 system, they changed the entire unit inside also. I did add an air purifier system, to deal with wifes alergies. Also had to make the air intake larger. Took about six hours for them to install it all and have it up and running.
Hal
Thanks everyone. The house is insulated pretty well.... it might be able to use a little more. One thing that might be a problem is the inside unit I've already replaced.....so I will have to find an outside unit that will work with the inside.
Thanks again, Tony
Thanks again, Tony
Not for sure that this is the info you're looking for....it is a Rheem Classic super quiet 80.
This is what is on the label...I couldn't find any info on the refrigerant.
Tony
Tony
