Had to pull the Comp off
Old Oct 14, 2003 | 10:06 PM
BigBlue's Avatar
I had to pull my Comp off cause my trans won't shift under full throttle with it turned OFF. It really sucks. Funny thing is that I only have 15 lbs of boost at WOT and my EGT's are pretty high (1200 on a 60* day on flat ground at WOT). It pulls pretty good for a stock truck. Plus the transmission isn't slipping or anything. Oh well.
Old Oct 14, 2003 | 10:27 PM
LE's Avatar
LE
Re:Had to pull the Comp off
Sounds like you have a MAP sensor problem. Have it checked and replace it if necessary. Your Cummins tech should be able to hook up his handheld diagnostic tool and check the voltage. They have been known to go bad when using a Comp due to the high voltage. I have had the same problem in the past. Good luck ........................... LE
Old Oct 14, 2003 | 11:05 PM
BigBlue's Avatar
I have digital gauges so that may be the problem. I'm gonna send all the senders back (except EGT) nad let Dakota Digital see if they are reading right.
Old Oct 15, 2003 | 06:02 AM
SjLingenfelter's Avatar
Dont mean to start anything but is it just me or are you having problems with your digitals lately? ???
Old Oct 15, 2003 | 02:00 PM
BigBlue's Avatar
I don't know. I'm pretty sure my boost gauge is fine. My FP is the only I've had trouble with.
Clucker
Jan 1, 2009 10:28 PM
tristan21
Competition / Pulls / OffRoad
15
Jun 5, 2008 02:25 PM
BigBLu
20
Feb 22, 2007 09:45 AM
dieselfan
16
Dec 6, 2006 10:16 PM
