Ground hog breakroom :)
REALLY old dog
Originally Posted by old dog View Post
Headsup fellow DTRotarions !
Eric got this great idea while taking his wife out to dinner Friday night at Tony`s Steak House !
He has graciously ordered a buffet breakfast for tomorrow morning !
It will include Steak & eggs -biscuits & gravy - hash browns -assorted fruits -cornbread -
coffee pho & Tea .
Make sure everyone is aware.
AND A BIG THANK YOU TO ERIC
Sorry guys but I just spent your breakfast money on a new truck. Beans and Wieners all around
coffee pho & Tea .
coffee pho & Tea .
coffee pho & Tea .
Ph00................
Have a gudurn,
Bob
Good morning all from ..........
Nice spread, thank you. Claude and Eric, do this more often.
Been another hectic week with lots going on. Had to drop all the other jobs that I was doing when the compressor at the orphanage died so I had to rush out and find another one. Fortunately some of the Canadian work team that were here last week donated the money for a new one. Bought a nice new Milwaukee Industrial 5 HP two cylinder cast iron, 220 volt compressor, 60 gallon tank for US$635. Not bad. Installed it and then went to turn it on. Nothing. Checked wiring and voltages, but still no start. Finally discovered that the motor is a three phase motor. They don't work very well on a single phase. Went back to the supplier and they admitted that they made a mistake and have ordered a single phase motor for me. Not sure what the amperage is on this new motor, but am concerned that the supply wires are too thin as I know already that I am pushing things Sure hope that I do not need to run new wires. Will check the voltage at the motor once I get it running.
This is a long weekend for me. Monday is a national holiday, so will stay home for a change. Have been neglecting my poor truck lately and just driving it, so tomorrow will give it some TLC and make sure that everything is tickety boo.
Off to get a coffee and do something useful.
Skipped the dogs and beans and made DW and myself omelettes, with a bit of ground buffalo for the meat.
Ouch. Just threw my elbow out patting myself on the back.
Cold this AM at 13° and clear. Just red on the news this morning there is a super storm headed toward us. They are saying it could almost have the intensity of hurricane Sandy by the time it hits the Bearing sea. Locally? Everyone tie down your garbage cans and park your planes into the wind.
Just made a fast dash to Bowling Green and back taking the Grand Son home. First trip in a LONG time that traffic moved smoothly, even through the 20 mile construction zone.
Came in here for some of the beans and wienies, but somebody licked the kettle clean. Made do with some of DW's Chili she made yesterday!! So there!!!
On second thought, if you wired a 3p motor into a 1p circuit without knowing it, you'd better get a little help.
Oh, I need help for sure
Maybe in more ways than one! I had ***-u-me-d that the motor was a single phase and wired it accordingly. Well, sort of. It was only when it did not start and I took a real close look at the plate on the motor that I realized my stupid mistake, especially as the starter had L1, L2 and L3 connections and not just L1 and L2.
Seriously tho', I do know how to wire this in.One question, have been told that the new motor (not seen it yet) has two capacitors mounted on it. With the capacitors, does it still need a starter, or can the starter be omitted and the motor wired directly to the pressure switch?
The compressor is approximately 60 feet from the main panel so maybe #10 wire is borderline? Perhaps I should use #8 for the run from the main panel to the breaker next to the compressor as my AWG chart shows a 2.7 voltage drop for that length of run at 22 amps? Will be there on Tuesday, so will take accurate measurements and also check the wire size feeding the main panel. The distance from the secondary breaker/switch to the compressor is only about 5 feet, so can use #10 for that.
I seriously doubt your pressure switch is rated for 5 hp. That's what the motor starter (relay) is for. Pilot (coil) current on the motor starter is a small fraction of the total load.
Thanks for the answer. Yes, the pressure switch has the standard unloader valve.
I am sure that you are correct about the amp rating for the pressure switch, so will use a starter.
In keeping with the ground hog theme, here is some sausage patties and links. Fresh STRONG coffee, not that wimpy stuff. Cinnamon raisin toast. And scrambled eggs.
10°. Need to find a spot that isn't a sheet of ice so I can transfer fuel.
