GM 4L60E tranny problem
Old Dec 28, 2005 | 10:56 AM
JDeere5105's Avatar
Hey guys, a friend of mine has a 1997 chevrolet 4x4 with a 4L60E trans in it. The problem that it is having is that it will not lock the torque converter up when it shifts into OD. It is not receiving the signal for whatever the reason.. Any help will be much appreciated. Thanks
Jason
Old Dec 28, 2005 | 11:14 AM
67HotRod's Avatar
Are you sure its going into od? Assuming this is while not towing anything. I know the 97 4l60E had a problem with a internal part breaking in the trans that prevents it from going into od. Having someone run a scan tool on it would help.
Old Dec 28, 2005 | 11:20 AM
JDeere5105's Avatar
It does shift 3 times, but then the TQ converter will not lock.. It does not get a signal according to the volt meter to lock up.
Old Dec 28, 2005 | 11:54 AM
67HotRod's Avatar
I would check for tsb's.
Old Dec 28, 2005 | 09:55 PM
electrifried's Avatar
The 4l80e had a reputation of eating the solonoid that controls the lockup. not too hard to change, just inside the pan.
Old Dec 29, 2005 | 05:14 AM
JDeere5105's Avatar
Thanks for the replies. I will pass the info along.
Jason
Old Dec 29, 2005 | 09:42 AM
JKM's Avatar
JKM
If it doesn't receive the signal to lock the converter, then he could have new solonoids , and still no go.
Old Dec 29, 2005 | 10:48 AM
67HotRod's Avatar
Want to say there was a tsb about the ecm/pcm not suppling the signal...
Old Dec 29, 2005 | 11:35 AM
Mr. Jimmy's Avatar
Not sure about the 4L60 but I had the same problem with a 700R4 and it was just the brakelight switch.
Black Dog
Dec 3, 2009 08:18 PM
wreedCTD
May 4, 2009 08:52 PM
94Stepside
Jun 25, 2007 09:46 PM
AlpineRAM
Mar 8, 2006 06:51 PM
silverram323
24
Nov 9, 2003 07:48 PM
