??? Furnace ???
Old Oct 14, 2008 | 06:36 PM
diesel_burner's Avatar
??? Furnace ???
Well since some of you have already experianced the cold, well we got it when I was in sunny Southern California last weekend. Got home last night to a cold house and turned up the termostate and nothing. First thing I think is that the pilot light was out, gas, so I told myself I can get through the night no problem. Well day two, pilot light is lite but no blower. I'm stumped on this one. I can do another night but not the whole winter.
Do you guys have any ideas? maybe I'm missing something? How much can I expect to pay for a new furnace if it is worst case?
Thanks
coldinnewmexico
Old Oct 14, 2008 | 07:34 PM
MegaRam's Avatar
I just said "To Hell With oil and gas from other country's"
Burn USA wood......
Old Oct 14, 2008 | 07:36 PM
I wish I could do that. I bet that puppy put out some heat.
Old Oct 14, 2008 | 07:39 PM
MegaRam's Avatar
Dying to find out.....
Old Oct 14, 2008 | 07:42 PM
D68's Avatar
D68
you say no blower are the burners lighting. and how old is the furnace.
Old Oct 14, 2008 | 07:46 PM
P.J's Avatar
P.J
Yes, if not you may be into a thermocouple. If it is shot it won't allow the burner to come on (thinks yo don't have a pilot lit and doesn't want to spew gas).
They DO go bad and are usually very easy to purchase and replace.
Old Oct 14, 2008 | 07:47 PM
Pilot light is light. There is power going to the blower, tested the socket. Blower does not move. The t-stat is up. The unit looks older but not ancient. worked when I bought the house in may.
Old Oct 14, 2008 | 07:53 PM
I'll do a little research on that, thanks.
megacabdad's Avatar
The pilot is lit, but the burners aren't coming on...
Is that what is happening?
Old Oct 14, 2008 | 07:55 PM
D68's Avatar
D68
stat is calling for heat but are the burnners lighting.
Old Oct 14, 2008 | 07:56 PM
Yes. Does that not make the blower come on?
P.J's Avatar
P.J
Actually, you may be able to search HERE for it, I think I got some advice on a wall propane unit a few winters ago.....
<EDIT> Never mind, can't find it.
Old Oct 14, 2008 | 08:13 PM
megacabdad's Avatar
diesel burner...
you got a pm.
Old Oct 14, 2008 | 08:54 PM
tool's Avatar
Had this happen with my furnace last Nov (and it was -30 at the time!)
Mine would short cycle, burner would come on, fan would never start and then burner would go out after a while.
(Thermo couple says it's getting too hot, stop)
After taking the panel off the furnace I gave the fan motor a shake and got sparks from the wiring!
Found the wiring was bad to the fan motor, removed fan motor, ran and tested it and then rewired and replaced fan motor.
Been fine ever since.
Old Oct 14, 2008 | 11:31 PM
12valve@heart's Avatar
If the burner is coming on and then cycling back off without the fan coming on, the problem could be in the temperature sensor that triggers the fan relay.
If the burner is not coming on at all, the problem may be be the thermocouple as P.J. mentioned or it could be in the thermostat not triggering the furnace.
turbox2
Dec 6, 2005 07:54 AM
caper
13
Sep 17, 2005 11:15 PM
ramlovingvet
Jun 6, 2005 09:14 PM
TPilaske
Oct 27, 2003 11:58 AM
BGDUMMY
Jun 10, 2003 02:59 PM
