Furnace problem!!!!
Old May 29, 2003 | 06:56 PM
BGDUMMY's Avatar
Furnace problem!!!!
If I have my furnace not turned up high, let's say 70 degrees it will run fine and cycle on and off. If I turn it up high (75 or higher) it will run fine then after running for a while it will start blowing cold air.<br>Any ideas as to what it could be?<br>Last year it was doing the same thing, so I took out and looked at it and the squirell cage had a mud daubers sp.? nest in it, so cleaned out and thought all was fine.
Old May 30, 2003 | 06:57 AM
Smokee's Avatar
Re:Furnace problem!!!!
Sounds to me as if you have problems with the high limit switch.
Old May 30, 2003 | 07:44 AM
trailblazenyj's Avatar
Sounds like a high limit or airflow problem to me. If your fan is running slow it will allow air to stack up and the high limit can pop. Also, if you have restricted supply or return ducts that can cause the high limit to pop also. Pretty easy to check if you can get access to a thermometer with a probe (or an infrared thermometer) and a meter. Not real sure about the proper temp range on a RV unit but it should be stamped on the high limit device. Homes are usually in the 150 - 190 range. (190 is a bit rare though). Set your meter to check continuity and turn the furnace on. Watch for the high limit to open and see what temp it did so at. Compare that to the rated temp and it will tell you if the switch is bad or if their is an airflow problem.<br><br>Good luck
Old May 30, 2003 | 11:01 AM
BGDUMMY's Avatar
Is the high limit switch the silver round disk with tabs on it?
Old May 30, 2003 | 08:45 PM
Gary, I've seen some of your posts so I know you are technically proficient (way beyond me when you start talking about air volume etc :-)). Sounds like you have checked everything. Main burner not coming on sounds kind of like incorrect gas pressure. Had a manometer on it? I think I read that most rv furnaces run around 11&quot;?<br><br>Also, that board sounds like a board honeywell used to use on big gas heaters. Flame proving wire could only be checked with a honeywell tester. Real pain.<br><br>BG: sounds like you found the high limit. I think they are pretty cheap if you can't test it.
Old Jun 1, 2003 | 09:35 AM
BGDUMMY's Avatar
Thanks trailblazenyj<br>I don't have any test equipment, but I may just remove it and replace, since you say they are not expensive.
Old Jun 10, 2003 | 02:59 PM
sidekick's Avatar
Try using a jumper (bypass) on the high limit switch, see if that works . Then you could at least eliminate that component. To me it sounds like a high limit switch. <br>Just my $.02
tool
Nov 6, 2007 05:37 PM
turbox2
Dec 6, 2005 07:54 AM
caper
13
Sep 17, 2005 11:15 PM
ramlovingvet
Jun 6, 2005 09:14 PM
TPilaske
Oct 27, 2003 11:58 AM
