ford 3000 tractor
Old May 22, 2007 | 06:43 PM
singleturnout's Avatar
ford 3000 tractor
alright guys i need some help. ive had this tractor for a year now and its sat for about 3 months i drained the fuel and the fuel filter, and changed the filter becuase it had some sludge in the tank. now it wont turn over how do i prime the pump. fuel getting to the filter just not going to the pump any ideas
Old May 22, 2007 | 07:45 PM
its acav it looks like the one in this link
http://brokentractor.com/ford-new-injector-pump.JPG
Old May 22, 2007 | 08:51 PM
bump bump
Old May 23, 2007 | 07:19 AM
thanks alot ,i will let you know how it goes
Old May 23, 2007 | 07:27 AM
samboats's Avatar
Ford tractor
I have a ford that sat for a long time before I got it. After replacing the fuel filter a few times I realized that that was not the problem. The shut-off valve coming out of the fuel tank had an opening that was real small and was getting clogged up. I replaced it with a 1/4 or 3/8 (can't remember which) ball valve and also an extra inline filter. Problem solved.
Old May 23, 2007 | 11:05 AM
well guys thanks for the info you are both right saab did what you told me and it fired right up,sam you were also right after it was running for a good 10 min it shut off on me. i pulled the needle valve from the fuel tank and no fuel was coming out. so i guess i got to drain the fuel again
ckt_santiago
Dec 26, 2018 03:55 PM
kyncl
Aug 4, 2008 09:39 AM
fishin fever
Mar 13, 2006 06:46 PM
plow
Jan 3, 2006 11:13 PM
Stamey
Apr 1, 2003 11:23 PM
