Electrical Q - 240v Compressor on 50 amp CB
Old Sep 27, 2007 | 03:53 PM
jlipskoc's Avatar
I have a 50 amp 240v welder receptacle in my garage, is it ok to put a 15 amp 240v air compressor on it?
I will not use both at the same time. I made a plug for my 240v compressor to plug into the 50 amp recept.
Concern is, if something shorts on the compressor, will the circuit breaker trip to slow or late, cause its 50 amps, not say 20 amps.
Theres an overload protection reset on the motor already.
Thanks
Old Sep 27, 2007 | 04:50 PM
John Faughn's Avatar
No problem if like you say , you do not run both at the same time .
Old Sep 27, 2007 | 06:41 PM
jlipskoc's Avatar
Thanks, wasn't sure if it was a bad thing to put low amperage item on high amperage breakers like that.
Old Sep 27, 2007 | 06:55 PM
gunny's Avatar
No problem to do it that way. If it makes you feel better, set another panel with a single breaker for the compressor at the outlet for the welder with the appropriate sized breaker for the compressor.
WhoCares79
Jun 3, 2008 11:45 AM
Camarogenius
Jun 25, 2007 08:55 PM
JKM
Mar 8, 2006 03:23 AM
