elec question
Old Jul 19, 2012 | 09:29 AM
olddodgetrucks's Avatar
elec question
time for annuall saftey,abs light is on,have found ground wire that turns on light in dash,would like to wire something into the wire that would turn off power after a few seconds and that would turn off abs light.
thanks
Old Jul 19, 2012 | 09:36 AM
rebal's Avatar
Radio shack 12 volt momentary (normaly closed)switch
Old Jul 19, 2012 | 10:10 AM
nkennedy's Avatar
If they hook up to your ODB2 port the code will still show up. In Texas they sometimes do hhok up, and sometimes just look at the dash for a engine light.
Old Jul 19, 2012 | 10:36 AM
they just look at light ,if it goes on when you turn key on and if light goes on in a few seconds you are good to go.
Old Jul 21, 2012 | 08:53 AM
No help so far,i thought by now some expert would tell what kind of gismo i could put in wire to do the job ?????
Old Jul 21, 2012 | 10:24 AM
j_martin's Avatar
You can get time delay relays in about any configuration you want. Look at places like digikey.com, or mouser.com
I could design the spoof circuit for you, but it is not worth the risk to me.
Old Jul 21, 2012 | 05:51 PM
chaikwa's Avatar
It would probably help if you had your truck listed in your signature so people would know what you have; year, model, etc. It would also help if you posted the question in the correct section that corresponds to your truck instead of the 'Other' section. Not everybody looks in here with any regularity.
Old Jul 21, 2012 | 06:37 PM
Bark's Avatar
If they just look at the light and if you have already isolated the wire I dont see why rebal's or j martin's suggestions wouldnt work.
Old Jul 21, 2012 | 11:15 PM
pind's Avatar
I know this is a dumb question. ( the kind I'm really good at ). Why not just fix the underlying problem properly, and have it over with?
There is a time to quick rig things, such as to get a unit to the shop or home, and there is a time to repair them properly. I used to do commercial vehicle inspections, and I got to find a LOT of fixes like the ones you are talking about. Then, faint of heart be warned, failure is imminent. Not fun for the owner of the unit, or for me.
Good luck with the inspection
04ctd
Feb 25, 2004 09:21 PM
jrturbot
Nov 23, 2003 01:46 PM
hotdram
30
Jun 26, 2003 04:35 PM
SolidJunkMM
Jun 21, 2003 08:09 AM
Demon_Customs
13
Dec 19, 2002 07:14 PM
