Easy way to pull off badges
Old Jan 20, 2004 | 12:31 PM
BigBlue's Avatar
For all of those people out there that want to remove your door badges and such, here's the easiest way I've found to do it. Take a plastic kitchen spatula (metal will scratch the paint) and some mineral spirits (must be mineral spirits, very mild remover). Drop some of the spirits behind the badge and wait maybe30 seconds. Take the spatula and pry behind the badge SLOWLY. The badge and the adhesive should come off. If there is still some adhesive left, get some Goo Gone or other similar stuff and apply it. Then peel it off. That's how I re-did the badges on my truck and it worked great. Just thought I'd share this info with you.
Old Jan 20, 2004 | 01:27 PM
spots's Avatar
fishing line also works very well. Varsol is the key tho.
Old Jan 20, 2004 | 04:36 PM
Dr. Evil's Avatar
There is adhesive remover that is specifically for automotive paint....WD-40 does a decent job and Ive heard that "Skin so Soft" also works.....goo gone may be harmful to paint.....
Old Jan 20, 2004 | 04:44 PM
magnum's Avatar
Not too much is going to be harmful to your paint if it is a fully cured clear coat.
(Although I'd still shy away from brake fluid) Any adhesive remover will work well, 3m, kent, and I'm sure theres other products out there. If you are really concerned about chemicals, just roll off any of the two faced tape remaining on your vehicle by using your thumb or fingers, just be aware that to a non-calloused hand, you can only get about 1-2 inches per digit before your finger will blister.
PS.. I've demo'd tossing a soaked rag with lacquer thinner and leaving it on paint for over an hour with no effect on the clear. Of course, it wasn't my vehicle
Old Jan 20, 2004 | 06:21 PM
Dr. Evil's Avatar
Thanks for the correction....
Old Jan 20, 2004 | 08:21 PM
BigBlue's Avatar
Snuff spit cups will do wonders on paint when left in the sun for to long.
Old Jan 20, 2004 | 09:29 PM
magnum's Avatar
Dr---Sorry, didn't mean to suggest you didn't know what you were doing, just trying to expaaanddd on your wonderful reply
Blue--never tried the spit cup, do I have to leave it in the sun, would like to try it just to do a demo..
Old Jan 20, 2004 | 11:24 PM
Dr. Evil's Avatar
Not at all...I believe you are a body man / paint guy arent you??? no doubt you know more about paint than I do. Thanks.
Old Jan 21, 2004 | 12:15 AM
BigBlue's Avatar
Don't know if it will work without the sun. I've only seen it done on a parked car in the sun. Some guy ticked off a bunch of FFA kids a couple years ago and right before school started, they dumped their cups on his hood and it sat outside in the full sun for 8 hours.
Old Jan 21, 2004 | 06:51 AM
magnum's Avatar
Be fun to try it........wonder if it would buff off???
Old Jan 21, 2004 | 08:26 AM
Redleg's Avatar
When I get pulled over, I always say, "Look! That Guy's drunk!" Then, I reach up and rip it right off........... you should see the expressions I get.
txarrowhunter
Aug 22, 2010 04:45 PM
wesboyd585
Dec 30, 2008 08:43 PM
caffecapri
16
Oct 7, 2008 09:58 AM
Txwelder
16
Sep 27, 2007 06:00 AM
Tiger Rag
20
Mar 8, 2006 04:39 AM
