disk brakes
Old Apr 12, 2006 | 10:02 AM
ruben's Avatar
disk brakes
has anyone had an experience of front disk pads wearing uneven;
that is; rear pad (inside) is almost new after forty thousand miles, front or
outer pad is half gone. What could cause this?
thanks for your input.
Old Apr 12, 2006 | 10:06 AM
tmleadr03's Avatar
Yes I have. It means you caliper slide pins are sticking. Either you can lube up the slides and all is good or you have to get new calipers. If its been stuck for a while, you will probably need new claipers.
Old Apr 12, 2006 | 11:44 AM
BigBlue's Avatar
Usually my inside wears quicker than my outside. It's done this since the truck was new.
Old Apr 12, 2006 | 11:50 AM
derek840378's Avatar
thats normal. the piston is on the inside, so it pushes the inside pad into the rotor before the caliper starts to slide. 99% of the time the inside pad will wear down faster
Old Apr 12, 2006 | 03:05 PM
tmleadr03's Avatar
Yes but the origonal poster is the oposit. Its sticking calipers. It will pull in evenly but because its sticking its holding the outside against the rotor longer.
Old Apr 12, 2006 | 03:07 PM
i was replying to what bigblue had said. u are correct if the outer pad is wearing faster, its the caliper pins not allowing the caliper to slide.
Old Apr 12, 2006 | 05:28 PM
tmleadr03's Avatar
Hmmm... guess it would help if took into consideration your quotes...
mhuppertz
Apr 3, 2010 05:14 PM
winkdemon
Aug 3, 2009 04:13 PM
cconrad331
Jan 27, 2008 09:47 AM
DSjockey
34
Jul 20, 2007 07:03 PM
wildcargo
Nov 29, 2005 04:20 AM
