Contact Chrysler
Contact Chrysler
Does anyone have a phone number for Chrysler Canada? A number to someone that will make something happen. Dealer can not fix my problem and this has gone on for a year now and I have had enough!
So 0 to 52,000 kms truck was great, no vibrations. Rear end goes and dealer does work on it and it comes out with a vibration at 52,000 kms and now I am a year later with 73000 kms still vibrates. Vibration does not change with engine rpm. I just want my truck fixed right, I do not think I am asking to much. Just need a real mechanic not a parts changer.
Cummins Guru
They most likely did not properly flush out the diff housing to remove metal particles the first time they rebuilt your diff. These particles get into the axle tubes and the wheel hubs and cause damage to these bearings and seals. Most flat rate mechanics will just pull the axle shafts out when they rebuild a diff. Did they even check for play in hub bearings?
Lets try and make it a click able link....
Chrysler Canada Inc - 200-10201 Southport Rd SW, Calgary, AB
I just did the copy URL and pasted it.
I had to show up in person at that building after my first 24 valve RAM had so many failed injector pumps.
They put me in touch in person with the regional warranty managers.
I have the name of one of the individuals that works there, the others are retired. If this is needed, PM me.
This may not help since RAM is a separate entity but it may.
Cummins Guru
I've rebuilt hundreds of these diffs over the 30 years with Chrysler and cleaning all the metal particles out of the housing takes some time. Todays mechanics do not want to spend the time to do the job correctly. I know I see it everyday at my job. They are always looking for the short cuts to beat warranty time. Sometimes they get away with it other times it comes back to bite them on the butt. Just like it did with the first rebuild they did on your diff. I hope you get your problem resolved, good luck.
BobT2004
Jul 2, 2004 07:02 AM
NJMurvin
22
Feb 1, 2004 10:23 PM
