Computer Problems
Old Apr 6, 2007 | 01:48 PM
acook's Avatar
Computer Problems
Ok im having some problems with my computer(desktop). While on the internet (explorer) i can browse through pages and after about 2-5 minutes ill get a message saying "iexplore has generated errors and will be closed by windows. You will need to restart the program an error log is being created" How do i fix it?
Old Apr 6, 2007 | 02:53 PM
dale29's Avatar
do a system restore to the day before you started having problems
Old Apr 6, 2007 | 03:04 PM
PanteraGSTK's Avatar
Not trying to over rule you or anything, but don't ever use system restore. It is very unreliable and you may lose important files.
Make sure you have all windows updates and then try again. If it still doesn't work get firefox as it is better anyway.
Old Apr 6, 2007 | 03:17 PM
nirion's Avatar
I wouldn't say firebox is better, but is a good alternative. I do agree that system restore is trash and should be avoided, much like a Ford 6.0 Liter.
Windows update should include IE 7 as an option, try it and see if that solves your problem, if not the other windows updates might. Another possibilty is spyware/malware or a virus.
Old Apr 6, 2007 | 03:44 PM
GhettoVaquero's Avatar
run every sort of anit virus and disk de frag utility you have. after you do all of that and it does not work use the system restore option that just installs the OS over again. If that does not work run a "full restore" (the option that says "not recommended" because you will lose files) and that will put your computer back to its original condition. If THAT does not work, buy a new HD and you will have to reinstall anything. If that does not even work, your computer is hosed and you need a new one.
Old Apr 7, 2007 | 02:57 AM
Timmay2's Avatar
If you are running IE 7 go into tools-options-advanced and reset browser. Typical cause is some sort of 3rd party plugin/add on that causes it. Also in the internet options delete all temporary files. Restart and try again.
If that doesnt fix it, you have spyware or virus troubles, and resolving those isnt a walk through online scenario unless you just want to erase it all and start over.
andywells
Feb 28, 2010 10:34 PM
Mud Ready
Sep 28, 2007 11:12 PM
boomer
Nov 28, 2005 07:58 PM
welder27
Dec 24, 2004 04:17 PM
Mexstan
Dec 10, 2003 04:05 PM
