on board air?
Old May 7, 2008 | 09:04 AM
evan3000's Avatar
on board air?
I need a decent amount of compressed air for my service truck. I don't really want to spent 8k for an under the hood screw compressor, so I was thinking about picking up a huge inverter and trying to run an electric air compressor. I currently have a 5hp Honda setup but I keep having problems with it not starting(mostly in the winter). Has anyone tried this? Thanx Evan
Old May 7, 2008 | 09:11 AM
Kenny D's Avatar
sounds like the volume of air you need you would be draining the batteries and or starining the altinator. Would a propane comp do better in the cold mabee its pretty easy to convert little engines just a carb swap i think just a thought
Old May 7, 2008 | 09:14 AM
t-boe's Avatar
How much air do you need (tool types, etc.).
Old May 7, 2008 | 10:40 AM
TonyB's Avatar
http://kilbyenterprises.com/KE-3100-K.htm
This is the basic compressor I'd like to run. However, in the interest of cost, I'm running a Viair 400 series electric
It does fine for air bags and OTR emergency tire change, etc. But if you are using a LOT of air (die grinder, etc) you'll want the York AC compressor that you see in kilby's website. That'll get you ~10cfm while the compressor is running.
The rest of the air system is the same basic stuff (tank, lines, regulator, etc)
Tony
Old May 7, 2008 | 03:21 PM
evan3000's Avatar
Thats exactly what I was looking for, Thanks Tony! I am mostly using the air for air tool. My Honda is rated for 6 cfm i think. so something like this would do the job. Has anybody ran one of these kits in there truck?
Old May 7, 2008 | 05:07 PM
TonyB's Avatar
Aside from cost, the only other thing keeping me from running this on my truck, is the fact that you have to eliminate the alternator clutch-pulley. i.e they substitute a 'regular' pulley so that they can put a regular v-belt in place to drive the compressor.
The clutch type alternator pulley eliminates a belt squeal/chirp, and seems to allow the belt to last longer.
There are a few guys running them. Do a search for 'on board air'.
Tony
Old May 7, 2008 | 05:19 PM
Harold-Pacbrake's Avatar
I'm not sure if this will help you much but I have quite a few tow truck's using it http://www.pacbrake.com/index.php?pa...ir-accessories
herb
Jul 18, 2008 08:25 AM
diesel_work
Aug 30, 2005 05:00 PM
firestorm
20
Nov 9, 2004 06:37 PM
zookeeper
14
Feb 23, 2004 09:05 AM
hellotbone
Nov 19, 2003 10:48 AM
