Biomass generators
Biomass generators
Anybody here have any experience with fairly large biomass generators for generating electricity and hot water from garbage?
If not biomass, what then?
Just realized I made a mistake in the title. I should have said biomass boilers. Don't know exactly how much power I need yet as I have not yet finished running the numbers. We would like to burn garbage or similar, such as what is generated in chicken farms to be more than self sufficient for electricity and hot water. Very briefly, we need this for 500 houses and a small hospital.
Chicken "biomass" is going to be a tough burn, with the high moisture level. It would take some figuring to see if it would be worth while. The plant I worked in made 1500 psi superheated steam to feed to the turbine, along with 150 psi saturated steam sold to the lumber plant, for use in the kilns.
reidry
Sep 7, 2006 08:04 AM
