Gas Generators
Old Apr 20, 2004 | 11:46 AM
ramlovingvet's Avatar
DTR'S Chaplain
Gas Generators
Okay I have a question.
I was given a generator that is not putting out enough voltage. If I increase RPM will voltage increase too?
if not any ideas?
Thanks
Old Apr 20, 2004 | 12:19 PM
Duelin's Avatar
Normaly----yes
remove enough stuff =air cleaner usually, to see the govenor adjustment nut on the linkage to the carburator. RIGHT TO TIGHT , usually results in increased RPM . use a good multi meter to SET the voltage to 115-120v AC.
Go fur it !!
nuff rain lately ? could use a break for lawn mowing !!!!
Old Apr 20, 2004 | 12:21 PM
shortround's Avatar
From: In the middle of Weather Dry Creek Farm in Avilla, Arkansas
I've got this three phase DC generator that's giving me problems.
Old Apr 20, 2004 | 12:22 PM
DTR'S Chaplain
Thanks Neighbor
Man way to much rain I am tired of mowing too. we have about 10 acres in the RV park to mow each time it gets sunny
Was up your way Thursday and passed through Sat on the way to and from Winchester Bay.
Old Apr 21, 2004 | 07:31 AM
redramnc's Avatar
What Duelin said ^^
If it drops under load it may be the governor acting up - kinda depends on which manufacturer's motor is doing the work as to how the governor works.
That is why tractor pto generators are subject to under/over voltage - usually a tractor governor doesn't govern under transient load well enough to keep the voltage extremely stable - but good enough for most things like pump motors and fans.
Old Apr 21, 2004 | 08:58 PM
2manydogs's Avatar
What make and model? If it's a Honda I can help. Jim
Old Apr 21, 2004 | 09:16 PM
jigdog's Avatar
cloudy
its cloudy now they say sun here for next few days.hope so
jj3500
Jan 18, 2007 08:40 PM
reidry
Sep 7, 2006 08:04 AM
mx261
Feb 9, 2005 10:57 PM
JAXFL1
Sep 8, 2004 10:01 AM
crobtex
Jun 22, 2004 03:49 PM
