Bathroom tile (shower) replacement
Old Jul 19, 2009 | 01:28 PM
rockcrawler304's Avatar
I need to replace the tile in the shower of my master bath. I have done several home improvement jobs so this does not bother me. I do however need some tips or advise as to the best way to do this and any possible problems I might run into.
One main question also is, will I need to remove the tub or can it stay in place?
Any help would be greatly appreciated. I can post or e-mail pics if it will help with the advise.
Thanks!
Old Jul 19, 2009 | 01:46 PM
digbog's Avatar
The tub shouldn't need to come out if it is in good shape. If it is not, now is the time to replace it. As far as the tile goes. If, when you rip off the old tile, it is green board or drywall, you should replace it with Durock or an equivalent product such as Permabase or Wonderboard. I like permabase because it cuts easy and screws easy. If you are using small tiles like 4x4 or 6x6 you can use mastic but if you are using full size tiles thinset would be a better option.
Old Jul 19, 2009 | 01:49 PM
jclaflin's Avatar
no need to remove tub. when you replace the sheetrock do not go back with sheetrock use durarock can get at your local homedepot or lowes good luck
Old Jul 19, 2009 | 02:01 PM
gadget.35-06's Avatar
Have a respirator handy. ESPECIALLY if the builder used ANY kind of drywall. My master shower was tile-over-greenboard and we ended up with mushrooms growing around the shower, from seepage into the framing. If you have mold damage you may have to have it professionally abated. I have a cousin going through that rigormorolle with her house right now...and her homeowners' insurance doesn't cover it.
Old Jul 19, 2009 | 02:02 PM
Thanks!
I do plan on replacing the underlayment. I am pretty sure it is a wounderboard type stuff.
I will be using a 6x6 tile, so you say the regular mastic will be OK?
I have not looked at grout yet but I assume there is a special grout for this application?
Old Jul 19, 2009 | 02:06 PM
There is some water damage which is why I am doing this. I am not sure if it was poor installation and water seeped in between the tiles or some thing else. The side with the damage is on an exterior wall and I am almost positive there would be no water lines inside that section of wall. But I could be wrong
Old Jul 19, 2009 | 02:13 PM
jclaflin's Avatar
if you go with a standered non sanded grout you can seal it or can spend a little more money a get a epoxy grout it is a little more work to install
Old Jul 19, 2009 | 10:55 PM
annabelle's Avatar
I always use a cement backer board with epoxy based mastic and grout. I use the caulk type grout you can find to go between the tile and tub (more flexible) no cracking.
Old Jul 20, 2009 | 12:10 AM
t-boe's Avatar
You can use a type 1 tile glue also instead of mastic. Make sure you tape the seams of your backerboard with an alkaline resistant mesh tape and use whatever tile mastic or glue as a "mud" to seal it up. It makes sure you have a water tight enclosure to prevent any future water damage. This is also a good time to change out your fixtures and raise or lower your shower head to fit your height. Don't go cheap on your grout sealer and don't get in a hurry applying it especially if you use a sanded grout.
Old Jul 20, 2009 | 11:07 AM
Didn't think about the tape part. THANKS!! And Iwill be putting new fixtures as well.
tanderson2002us
13
Apr 24, 2009 10:26 AM
Mule Skinner
Apr 7, 2009 03:38 PM
2500CTD
Sep 3, 2005 09:06 AM
04ctd
Nov 26, 2004 06:40 PM
04ctd
Mar 19, 2004 08:59 AM
