Ball-valve Question
Old Jul 11, 2007 | 08:54 AM
BearKiller's Avatar
Question Ball-valve Question
I can't find the information that I need in the product description.
Miniature chrome-plated brass ball-valve, part # 4912K77, with 1/4 NPT female ports, from:
http://www.mcmaster.com
My question is, considering that the 1/4 NPT female threaded hole is of larger diameter than 3/8 ID hose, will this valve flow 3/8 I.D. all the way through, or will it be a restriction.
If it won't carry 3/8, which NPT size miniature ball-valve will??
Thanks.
Old Jul 11, 2007 | 09:32 AM
tristan21's Avatar
1/4" measures 5/16" ID and 3/8" measrues 7/16" ID so a 1/4" will probably give you some restriction. I would go with 3/8"
Old Jul 11, 2007 | 12:34 PM
Raspy's Avatar
You can't tell without either looking through the valve or by seeing the description where it says "Full Flow". Manny cheaper ball valves, or older ones, have a smaller hole in the ball than the inside diameter of the pipe that screws into them. As long as it's not way smaller, or you are right at your flow limit and can't stand a little more restriction, it's not much of a problem. But full flow valves are always better and I look through every type I get just to see.
John
Old Jul 11, 2007 | 12:44 PM
Lil Dog's Avatar
Try looking for "full bore" ball valves where they have purposely oversized the casing for the ball ID to be the same as the piping.
Old Jul 11, 2007 | 06:37 PM
Fronty Owner's Avatar
what are you trying to do?
3/8 is an uncommon size. either go 1/2 or 1/4. If a 1/4" valve is a problem, your undersized at 3/8"
Old Jul 11, 2007 | 07:27 PM
Raspy's Avatar
I think he's referring to the actual measured size of the hole, not the pipe size.
John
Old Jul 11, 2007 | 07:50 PM
Yea, the restriction in a ball valve is so small and so short that if 1/8" diameter is going to matter in the system, then 10 feet of 3/8" hose is going to have more restriction than the one valve.
Old Jul 11, 2007 | 08:47 PM
phloop's Avatar
If full bore or full flow does not turn up much, try full port. I believe that is the proper term used.
firebill1720
20
Mar 5, 2010 09:23 AM
Wulzcat
Dec 19, 2009 05:15 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
welndmn
Jan 31, 2007 07:59 PM
