Back support belt?
Back support belts
As a safety specialist ( my job), I can tell you that back belts are or should be prohibited at your work site UNLESS prescribed by a doctor. They can actually do more harm than good (false sense of security, impropper use, etc.)
There are several studies on the problems with use.
Good luck. Be safe.
Good luck. Be safe.
I shoe horses for a living and have looked into useing a back belt for stability.
The doctor told me it would not be a good idea, because I would become dependant on it. I would say learning how to lift properly, and shift your weight(in my case)is a much better option. I have just learned after 17 years of shoeing full time that a chiropractor and message can do wonders.
The ONLY time I use a belt is when lifting very heavy at the gym. Squats or dead lift.
Other than that I've heard the same thing - bad.
Try getting into a good ab routine - build up the lower back. Much better than a back support any day!
I use one when I have to unload full trailers of equipment by hand. The belt works by making you lift things correctly. They are not made to make you stronger. I can tell you that my back hurts if I don't wear one while doing the same work......
I always have mine in the truck just in case....
DodgeDiesel61
Jan 26, 2019 07:45 PM
DodgeDiesel61
0
Jul 28, 2010 11:14 AM
JoshPeters
Apr 3, 2005 08:13 AM
