Any excel / access gurus here?
Old Jul 29, 2007 | 05:52 PM
EKUgrad's Avatar
This is probably simple for you guys, but would any of you know of any way where, if I place a numeric code in one column (that has a set $ charge established for that code) the $ value would automatically be drawn in to another column?
Thanks.
Old Jul 29, 2007 | 07:45 PM
Fordzilla's Avatar
Ask here: http://www.utteraccess.com/forums/index.php?Cat= ...Ben
Old Jul 29, 2007 | 07:57 PM
nirion's Avatar
Yes, but are you doing it in access or excel? Either way you will have to create a list with the numeric codes and their corresponding $$ amounts. In access, you would have a table with the codes and amounts. Then you would query them when you needed it.
Old Jul 29, 2007 | 09:56 PM
EKUgrad's Avatar
Thanks everyone. I will try to work on it some more tomorrow. I don't really care which program I use, whichever I can get to work first.
Old Jul 29, 2007 | 10:05 PM
graphitecumnz's Avatar
In excel you can use the VLOOKUP function but you will have to have all of your numeric codes and their corresponding values in an array somewhere in your workbook. It's really simple to setup.
Old Jul 30, 2007 | 08:39 AM
bamadzl's Avatar
This is the simplest way I know of, also. VLOOKUP (stands for vertical lookup) is pretty simple and it does just what you need. Another similar function is HLOOKUP.
Brad
Old Jul 30, 2007 | 08:41 AM
nirion's Avatar
Vlookup is good stuff. It has saved me a lot of time. Depending on what you are actually doing will determine which program will be best for you to use.
wyododge
Aug 18, 2011 07:48 AM
hamilton71801
Oct 17, 2008 07:10 PM
Grim Reaper
Mar 20, 2006 12:31 PM
AggieJustin
Jan 29, 2006 08:42 AM
HdPower
Nov 17, 2004 06:00 AM
