Almost ready for the lake
Old Jul 2, 2011 | 02:54 PM
hamilton71801's Avatar
Just have to wax her and clean the inside. I might put in fresh gas and check the carbs since it hasn't been in the water for a couple of years. Not too bad for a 33yr old boat...
Old Jul 2, 2011 | 04:22 PM
Bark's Avatar
Fun Stuff.
Hey!! There is a flying saucer in the upper right corner of your picture. More proof that they exist. You probably can't see it because they erased your memory. You might not even remember saying I could borrow your boat.
Old Jul 2, 2011 | 04:28 PM
cbrahs's Avatar
fresh gas a must. nothing sucks worse then hauling **** across the lake, power starting to reduce, funny look on face and.............. silence (other than the water up against the side of the boat). motor dead, carbs gunked up, garbage plugging jets etc......
Old Jul 2, 2011 | 04:41 PM
Scotty's Avatar
Top's Younger Twin
That is not a UFO its Chris' 9 volt KOMODO MOBILE after the catapult test.
Old Jul 2, 2011 | 11:22 PM
cbrahs's Avatar
dang it. you caught me again. I am going to have to be a bit more sneaky to keep the paparazzi out!
Old Jul 3, 2011 | 08:39 AM
Shorts's Avatar
Definitely fresh gas it if you can. You don't want your fun toy motor to spoil the fun.
I think we're heading out to the lake today. Better start getting ready.
Old Jul 3, 2011 | 10:11 AM
Hvytrkmech's Avatar
I would run it on a set of ears for a solid hour, idle for a while then higher RPM's for a bit. Do that back and forth, makes sure the engine gets hot. I would also higher recommend a marine fuel system additive to help clean out the system and deal with the methanol in the gas.
Have fun and be safe out there.
Old Jul 3, 2011 | 10:33 AM
Rob's Red Ram's Avatar
They really do exsist!
Old Jul 3, 2011 | 10:34 AM
ps yes on FRESH gas .only as much as u think u need as todays gas is terrible.And not very marine/boat friendly from what I have been hearing.Use that new Stabil marine formula.BE safe
Old Jul 3, 2011 | 01:01 PM
ChrisJohnson's Avatar
Check out this website for "real" gasoline! http://pure-gas.org/index.jsp
Old Jul 3, 2011 | 05:39 PM
Luckily the stations around here sale non ethenol so I should be good. I put fresh gas in and she busted off pretty quick. Cleaned out the dirt dobber mud from the pee hole so I should be ready to go. Nothing like a Mercury!!!
Old Jul 3, 2011 | 11:15 PM
scuzman00's Avatar
At least you have water in your lake.... Around these parts its been so long since it rained that the lakes have dropped 6-15 feet. Most places do not have enough water to get your feet wet, much less get your boat in the water.... Have a blast!!!!!!!!!!!!!!!!
Gary
Old Jul 4, 2011 | 10:22 AM
S.TX.MEGA's Avatar
[QUOTE=Hvytrkmech;2988869]I would run it on a set of ears for a solid hour, idle for a while then higher RPM's for a bit. Do that back and forth, makes sure the engine gets hot.
^^^^If it hasn't been run for a few years listen for the valves. My friend has a similar boat from the mid seventies and one year after siting for a while one of the reeds stuck. When it unstuck it broke off. Time for a complete overhaul. Oh yea watch out for the nylon sleeve in the prop it could be dry rotted and spin off under load. My friend is still running the original 115 hp 2 stroke Mercury.
Just a few things to think about before you're far away from shore.
Old Jul 4, 2011 | 11:53 AM
cougar's Avatar
Bring along a box of tampons just encase you spring a leak.
Old Jul 4, 2011 | 05:00 PM
Originally Posted by Bark
Fun Stuff.
I just now saw what your talking about and was believing it myself until I realized I have a hummingbird feeder hanging off the porch!
