'91 Lumina Power Steering
Old Nov 8, 2003 | 02:03 PM
Shovelhead's Avatar
Administrator / Scooter Bum
BIL has a 91 Lumina that has a P/S problem.
The fluid is "boiling" out of the pump resovoir.
Anyone have any ideas?
He says the Mechanic down the street is quoting $700 to fix.
BIL doesn't know what they're supposed to do fix it for that $700. :
Did I mention that he is totally mechanically illiterate?
Old Nov 8, 2003 | 02:08 PM
Monty's Avatar
Re:'91 Lumina Power Steering
It almost sounds to me like the check valve inside the ps pump that controls the pressure on hard turns is malfunctioning and not allowing the fluid to bypass. Just my opinion though. ???
Old Nov 8, 2003 | 02:21 PM
Shovelhead's Avatar
That's exactly the kind of responses I'm hoping for.
Thanks.
Keep 'em coming.
Old Nov 8, 2003 | 04:33 PM
spots's Avatar
Can you get more info from the tech. Kinda hard to diag it this far away. Does the steering work properly other than belching fluid??
Old Nov 8, 2003 | 05:15 PM
Shovelhead's Avatar
He says it works until the fluid "Boils" (his words) out of the resivoir.
Then the steering gets hard.
Yeah I know it's like trying to diagnose a "pain" over the phone.
The ONLY time he ever calls is to tell me one of his cars is "broken" again.
Old Nov 8, 2003 | 10:36 PM
RamDan03's Avatar
It may sound obvious, but if water has become trapped in the system, this could be causing the boiling. Refilling and bleeding the system may be worth trying before dropping $700 bucks. Another thing to check is to make sure none of the PS cooling lines are kinked. The valve mentioned above also sounds like a good possibility. However, if the Lumina is a 3.1 V6, the PS pump is only about $50 at Advance Auto Parts. I changed one a few years on the Ex's Corsica 3.1
tony99
Apr 9, 2014 08:25 AM
Dean Snow
Nov 14, 2007 04:36 PM
Crimedog
Feb 6, 2007 09:30 PM
DodgeCowboy
Aug 28, 2006 08:57 PM
Garz
Nov 17, 2002 02:02 PM
