110v Electrical Help
Old Oct 4, 2002 | 07:37 PM
admin's Avatar
Re:110v Electrical Help
134 volts? Was your electrician on crack or something? Either that or your power company needs to get on the stick with power regulation. Im by no means an expert, but that's pretty high.
Old Oct 4, 2002 | 07:39 PM
Shovelhead's Avatar
Administrator / Scooter Bum
That sounds waaay out of range to me too. <br>I'd be checking with the Power Company.
Old Oct 4, 2002 | 07:54 PM
admin's Avatar
hehehe. What year was it built, 1949? <br><br>Sorry, couldn't resist. My house is kinda funny like that too. It was built in 1963.
Old Oct 4, 2002 | 07:58 PM
NWDave's Avatar
Can you get to your main feeders in your house panel? You need to get some voltage readings across the main feeders coming into the house. You will have to remove the cover to get to the feeders. These will normally be the largest wires coming into the cabinet, usually marked with phase tape (not necessarily so) but the NEUTRAL will be marked with WHITE phase tape. Voltage levels vary from region to region but should be within the range of 210 to about 240 volts across the main feeders. You should naturally read half that amount when going from one main to GROUND. You should have a ground connection in your cabinet. How about other outlets in your house? Are they showing the same voltages? If you still have high voltage readings especially if they're seen across the feeders, like 280 volts (your 134.9 v tells me you're using a digital voltmeter) call your power company immediately. You're being supplied about 40 volts too much. But they need to know what the feeder voltage is. That's all they care about, what comes from the stepdown transformer to your residence house panel. Does this make sense to you?<br><br>~Dave
admin's Avatar
<br><br>You kill me Gonzo.
Old Oct 4, 2002 | 08:01 PM
NWDave's Avatar
Just read the post about the routing of your power supply to your house. You say it comes in on a pole, drops to shop panel. Where is the meter? You need to measure the incoming feeders at the next item connected. I'm assuming the shop?
Old Oct 4, 2002 | 08:14 PM
NWDave's Avatar
Can you duplicate that spike?
Old Oct 4, 2002 | 08:19 PM
NWDave's Avatar
If you get that voltage spike repeatedly, they have a voltage regulation problem. You need to get ahold of your power company. By the way, what kind of voltage protection do you have on your computer? Those type of spikes could crispy fry that baby if it's not well protected. <br><br>~Dave
Old Oct 4, 2002 | 08:23 PM
NWDave's Avatar
Ok, get that power company on the line asap. They have a voltage regulation problem that needs looking at immediately. I'd remove anything sensitive from those voltage sources unless you've got excellent surge protectors. <br><br>~Dave
