Jeep stuck in the mud
Yesterday a co-worker came to me and asked me to pull his Jeep liberty out of some mud. He was burried so deep that none of the 4 tires were even touching the ground any more. We tried to pull it out with just some tow straps but I broke one so we doubled them up and utilized 3 of them for more strength but all I did was spin. It sucks when you spin all 4 tires at one time. So I was looking for something other then a winch (too much money) to pull a stuck truck out of the mud. Please let me know what you all use. Thank you in advance for the help.
John
John
Well
its not a winch, and they are four 2 x 4's i have in the bed, as well as a shovel.. Stucks are usually accidental, i understand that, but I try not to put myself in that situation.... it sucks...
Ive only had to use my boards once in sand, and had to be pulled out once...
Try a super heavy duty come along and a pull pal.....
Not fun either way
Tx
Ive only had to use my boards once in sand, and had to be pulled out once...Try a super heavy duty come along and a pull pal.....
Not fun either way
Tx
If your going to use the snap method put a jacket or blanket on the line it will keep it fromm going thru the window if it breaks. might get a bumper jack and raise the front and push it over to get part of the frame off the ground cuz your plowing with it if the tires arent touching
Sounds like it is really stuck good... Get a high lift jack and some boards.. Jack up the Jeep and put the boards under the tires to get the frame out of the mud.. Hook up the tow strap and drive it out with some pressure from the strap...
Alot of work but it got my froends full size chevy out of the muck.. His was a lifted truck with 36" tires buried to the doors...
Gerry
Gerry
Its out
Thank you all for the Replys they were great.
NC MOG you were right he did not have any attachment points so we had to use his axle.
In the end he called a tow truck and they winched him out. I have seen some 4ton come-alongs for about $35 and was wondering if they would be worth while? I live in UpState NY so this will probably not be the last vehicle that I am asked to pull out before this coming winter is over.
Again thank you for the sugestions!!!
John
John
