Control arms too long?
can you use 3" lift kit lower control arms if you are only running a 2" leveling kit? Friend of mine ordered his 3" lift kit for his 98 1500 and waited to install it so I could try and copy the lower control arms for my 2500 so my 315's dont rub when I get them. Just curious if they are too long and if so how much should I shorten them? Just to stock length? As long as both lowers are the same length does it matter if they are off by a little as far as length goes? Thanks.
I know the Rancho 3" lift comes with the fancy boxed red lower arms but they are the same length as the stockers. If these do happen to be longer then the only thing is you will want to make sure that your caster can be put back within factory specs. If all arms were replaced, an inch or two long would not hurt and actually would be better because the tires will hit the fenders sooner then the bumper in the stock location, so longer arms would push the axle away giving room for larger tires.
Exactly. If you go too long they'll push the tires into the bumper, which obviously is no good. Carli's arms are 1/2" longer than stock and work perfectly with their 3" system.
DIESELWRKS
13
Nov 2, 2010 08:15 PM
04ctd
Feb 9, 2006 12:04 AM
cheff
Jan 23, 2006 09:44 AM
