Off Road / 4x4 OffRoad discussion, along with 4x4 events and information.
Chrysler 8.25
Old Nov 27, 2007 | 01:24 PM
ol' 93 12 valve's Avatar
Chrysler 8.25
i have a dodge dakota with a 8.25 and dont want anymore one wheeler peeler. should i go with a limited slip, posi traction, spool, or locker. i have already thought about welding the rear end but dont want to burn up tires. all help is appreciated.
thanks
Old Nov 27, 2007 | 01:25 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
it all depends on what your intentions are for the truck
Old Nov 27, 2007 | 01:29 PM
JPR Ram's Avatar
Streat use, a good LSD (same as posi). Staight line track use, spool. trail running, locker. I'd stay away from a "lincoln locker" unless your doing anything but offroading and even then I'd be leary.
Old Nov 27, 2007 | 02:03 PM
well this truck will be drivin mostly on the street but there will be some off road use. its going in a 1991 dodge dakota 4wd.
Old Nov 27, 2007 | 02:18 PM
JPR Ram's Avatar
In that case, I'd either stick to a good limited slip or posi. If you're on an unlimited budget, maybe an ARB air locker; best of both worlds. Your 8.25 probably has 26 spline axles. If you replace the whole differintial, I'd also up grade to the new 29 spline axles.
And diffenintely stay away from a spool and/or a "lincoln locker". You'll tear up tires and drivetrain parts like crazy; the truck will be a PITA to turn a corner or a curve in the road; and it'll just be a pain driving all together.
Old Nov 27, 2007 | 02:25 PM
im only 16 and dont make very much money working. so the cheaper the better. the axles are actually 27 spline. do you know of a good company for getting a limited slip or posi?
thanks
Old Nov 27, 2007 | 02:35 PM
JPR Ram's Avatar
Opps. you're right. It's been a long time since I've dealt with an 8.25 diff. Detriot Locker makes a good LS. You know, maybe an EZ locker would work. Either Detriot or LockRite. Not as smooth as a limited slip. Can also get a little touchy on a wet road. But as long as you remember it's back there..........And of course the price is right. OR maybe search local wrecking yards. That same axle also came in Jeep XJ Cherokee's in the 90's. Up to '96, I believe, you'd find the 27 slpine. '97 to 2000 you can find 29 splines axles. My point is, LSD came from the factory as an option. Maybe you'd get lucky and find one, cheap.
Old Nov 27, 2007 | 02:47 PM
JPR Ram's Avatar
The Detriot LS is a True-Trac. And it LockRight, not Lock-Rite. My bad. Anyways here-->http://www.quadratec.com/products/pr...kers&c=55&pg=1
These are listed for Jeeps, But a 8.25 is an 8.25. The only thing that matters is whether it's a 27 slpine or 29(?) spline axles....
Old Nov 27, 2007 | 03:43 PM
cbtumedic's Avatar
If you are into junk yard diving then look for a cherokee with an 8.25 and limited slip in it, My '97 has the up-country package with the lsd and it is great, it operates very tight, in fact almost too tight on the street and if you find one in the junk yard it'd probably be pretty cheap.
Old Nov 28, 2007 | 09:00 AM
Lock-Right makes a mechanically-operated unit for $378 at randys ring and pinion. And TracLoc makes a complete Posi Traction for $271 at randys ring and pinion. do these sound reasonable. it would be my luck that the posi out of the junk yard is garbage.
thanks
RickG
Nov 3, 2006 02:44 PM
westcoaster
Dec 28, 2002 07:13 PM
admin
Site News
Dec 18, 2002 02:16 PM
PistolWhipt
Nov 7, 2002 05:27 PM
MrBilly
Oct 21, 2002 09:37 PM
