NJDTR #37 Forum for the New Jersey chapter #37
Gatherings 2
Old Oct 15, 2008 | 06:17 PM
  #481
mulisha's Avatar
weather.............................?
Old Oct 16, 2008 | 07:30 PM
  #482
mulisha's Avatar
mike ill be at the track around 6:30, you still going
Old Oct 16, 2008 | 09:07 PM
  #483
mikmaze's Avatar
good possibility, just got home and a bit of a tough week, but the track is callin my name....... will have to play the weather by ear. at the least I need to stop home and toss the tires in the truck, got the fuse for the compressors replaced so I got air again !
Old Oct 17, 2008 | 03:44 PM
  #484
mikmaze's Avatar
yeah what the heck , got the tires loaded, did not forget the floor jack, so I am headin up in a bit, anyone else interested come on up to Island dragway, great meadows, NJ
Old Oct 17, 2008 | 06:31 PM
  #485
Juniorphil's Avatar
Not makingit sounds like fuun have not been there in a bit. Getting ready to head out to FALL BRAWL tomarrow should be a blast.
I will probably leave around 6am if thing go accordingly.
Old Oct 17, 2008 | 10:04 PM
  #486
mikmaze's Avatar
just got back from the track had a good time, bit of a chill in the air... ran a little better ont he stock tires, but still not beatin my personal best, only ran twice lines kinda long. I did hand it to a must rust tho drove home on the stock tires, man I miss the 35.s 2300 rpm to do 70 on the gps vs 1900, too late to change them tonight, might just swap the 35's on in the am b4 I head to fall brawl. Gotta find my lower psi switch for the air system, blew another fuse tonight, think 200 psi is too much to ask.
Old Oct 17, 2008 | 10:17 PM
  #487
Patriot2500's Avatar
Mike sorry got your message late and by the time I got to the track it probably would have been time to leave. What were your times with the stock tires?
Old Oct 18, 2008 | 07:51 PM
  #488
mikmaze's Avatar
I ran fifteen flat, my 60 foot time was a lot better, but by the end of the run it all seems to come out the same......... dyno'd out at fall brawl today, got a reading of about what I expected.,, a measly 360 hp, 722 tq. so for now I have about had it, seems like this is as fast as my truyck wants to go. then again, I still have to get the water meth kit in, and then I am going to try the tnt software. my run today was what I drive daily, revo, sw 7, timing for stock injectors, tm 3. run was real clean like I definately have room for fuel. saw a lot of good people out there today, no less than 60 trucks, and watched 2 dyno over a thousand hp, both on fuel only I think. was a blast, well worth the drive of 3 hours.
Old Oct 19, 2008 | 10:05 AM
  #489
Juniorphil's Avatar
yeah it was a great time out at the Fall Brawl. it was cool to see the over 1000 Hp readings. those trucks sounded bad a?? . There were a lot of nice trucks out there and most of the big HP trucks looked like your daily work trucks. Good to meet a lot of new faces, and finaly dynoed my truck. It was were i thought it was around at 360HP and 843TQ. I definetly need more air from a larger turbo, the stocker isn't cutting it.
Lik,e mike said his truck burned very clean and def. could use more fuel.
I have a bunch of pics and vids and will try to post when i get a chacne, as for know you will have to wait.
Old Oct 19, 2008 | 02:02 PM
  #490
mulisha's Avatar
mike, i used the HP calculator over at competition diesel. i put your weight at 7600lbs, toolchest plus tools ect. it puts you at 363hp.i also used your et time,and trap speed, same thing 366hp. that thing is dead on, cause i did mine and it was within 10 hp.
Old Oct 19, 2008 | 03:16 PM
  #491
mikmaze's Avatar
yeah, not sayin the dyno is off, just that my truck dissapoints me......
Old Oct 19, 2008 | 03:32 PM
  #492
mulisha's Avatar
90hp DDP'S, and a turbo, and the tnt youll be at 500. nothing wrong with that right.plus if you would of dyno'd in sw9 you would of saw 390
Old Oct 19, 2008 | 03:37 PM
  #493
mikmaze's Avatar
what irks me is I know of one fellow that claims 518 on smarty alone, stock stix, and stock turbo...... maybe he's addin stickers up, ah oh well.
Old Oct 19, 2008 | 06:45 PM
  #494
Green04HO's Avatar
Originally Posted by mikmaze
dyno'd out at fall brawl today, got a reading of about what I expected.,, a measly 360 hp, 722 tq. my run today was what I drive daily, revo, sw 7, timing for stock injectors, tm 3.
Mike this just does not sound right. SW 7 should be a 130hp program. It should of put you over 400. You only got approx. 85 hp out of it. SW 9 should put you at 445-450. You should dyno 275hp give or take stock.
With a 230hp program you should be over 500 like I did with the C5.
Old Oct 19, 2008 | 06:47 PM
  #495
Green04HO's Avatar
That's why they call that dyno the "Humbler". I still think you have something going on though.
