MODTR #30 Forum for the Missouri chapter #30
MODTR-30 Chapter thread
Old Sep 19, 2007 | 08:16 AM
  #406
Chrisreyn's Avatar
Darrin, dont you DARE tell teh BOSS you are gonna be putting that truck on teh market..... we cant afford that!
Old Sep 19, 2007 | 09:15 AM
  #407
puffsmokeonya's Avatar
whos all ready for harrison pull? i would like to have a weight bar on mine so i could look like i was gonna pull hehe. then i could get in for free
Old Sep 19, 2007 | 12:32 PM
  #408
Tree DR's Avatar
Remember Chris I've got your Ph#.....
Old Sep 19, 2007 | 05:31 PM
  #409
Pack Mule's Avatar
ya'll i think we all need to go to the benefit pull in belle mo. it's a haul for everyone but i'm thinking strong about goin. what does EVERYONE else think about it????
Old Sep 19, 2007 | 05:44 PM
  #410
Ground Shaker's Avatar
Pack, I had already planned on going. Alot of the guys had already planned on going. Its for a great cause so I see no reason why not. Its not that bad of a drive for me for darren, but pack if you just come up to springfield and shoot across 44 with us I don't think its gonna be that bad a drive. Heck I drove to Mtn Home the past two weekend, this should be an easy desicion.
Old Sep 19, 2007 | 06:52 PM
  #411
Tree DR's Avatar
Crazy
Originally Posted by satburn
Got a 30lbs gauge I'm not using anymore... throw me an offer.
Well I did it again. Just took the wastegate actuator off my cracked turbo and straped it to the frame and pluged it in. Now I have a little more low end power. But the MAP boost is only getting above 34psi where as before it went to 37.4psi. What's going on? Why not over boost instead of low boost?
Old Sep 19, 2007 | 07:37 PM
  #412
Pack Mule's Avatar
i knew there was a couple that planned on goin i was refering to everyone that hadn't made plans. and thank you for the directions not to be a smart a&&. i'm going to try and talk chris into pulling his. that would be fun. darren you need to put some sort of ohm resistor in between the actuator and harness. that will let it build more boost. and the amount of fuel you put into your motor will be a big determining factor in boost.
Old Sep 19, 2007 | 07:53 PM
  #413
coreydr2003's Avatar
Ill B There
Old Sep 19, 2007 | 09:20 PM
  #414
Originally Posted by coreydr2003
Ill B There
Really? I thought you were going to south africa that day?
Old Sep 20, 2007 | 12:31 AM
  #415
satburn's Avatar
Originally Posted by Ground Shaker
I'd use gorilla glue if I were you.... I can't figure that out, I got a feeling something little is going to show to work.
I'm thinking that glue is going to be it. Driver's side motor mount wasn't tight, tight so I gave it another twist. Clamps I have are the spring kind and so wide that I can get more than one in between the ribs.
Old Sep 20, 2007 | 02:53 AM
  #416
I'm telling you, gorilla glue!
Old Sep 20, 2007 | 10:12 AM
  #417
Chrisreyn's Avatar
Brian, If I recall correctly the IC piping is 3 1/2 inches?
why not get a short stub of the same size exhaust piping and put a "spacer" in teh middle of the boot to lengthen it?
Old Sep 20, 2007 | 11:32 AM
  #418
Pack Mule's Avatar
problem there chris. the boots are only at each end. he'd have to lenghten the tube itself to make that work.
Old Sep 20, 2007 | 03:01 PM
  #419
i think satburn should just weld his motor to the frame then get longer intercooler pipes and weld those to the intercooler. problem fixed. just kidding
Old Sep 20, 2007 | 03:25 PM
  #420
Pack Mule's Avatar
huh uh he needs to take a bunch of jb weld and make intercooler piping and the jb weld it to the intercooler. and get rid of the motor mounts and use motor plates.
