Won't Go into gear
no adjustment on them, its all hydraulic. its either a damaged pilot bearing thats seized up and causing the input to spin when you push the clutch in, or you need upgraded hydraulics cause the stock ones are weak and not pushing the pressure plate far enough
Hey I'm dealing with this right now also. I have done the hydo's and changed to synthetic. Neither one has helped. Prob the pilot bearing.
Does it help if you put it in 5th gear before you go to 2nd or Reverse?
call valair and find out if you need to lengthen the slave cylinder rod.
CRM04
May 18, 2008 10:35 PM
