Never ending Thread XI
Old Jan 31, 2013 | 07:38 AM
  #826
bigsingle's Avatar
Originally Posted by b4wheeler
Mine throws a crank position sensor code every now and then, but the check engine light goes out after a few restarts...
I didn't think our trucks even had crank position sensors... I know there is a cam position sensor.....
98-00 uses a crank sensor for the tach pickup, and has a cam sensor tho i dont think it really does anything.
01-02 does not have the crank sensor and uses the cam sensor only for picking up tach signal.
Old Feb 12, 2013 | 12:28 PM
  #827
Sea:\>Drive's Avatar
Funny Story!!!
So my daughter is 16 and has her learners. Once she gets her license she'll most often drive the truck for a while so this past weekend I wanted her to be comfortable with it.
She gets in the truck - turns the key, and the motor stumbles and quits, stumbles and quits, stumbles and quits - with complete panick she says "Daddy it won't start!!!!"
Me: Did you wait for the "Wait to Start" light to go out?
Her lesson was learned.
Old Apr 17, 2013 | 08:51 PM
  #828
Crabjoe's Avatar
Will this thread ever get moving again??
Old Apr 18, 2013 | 09:35 PM
  #829
ramsport59's Avatar
Nah...
Rick
Old Apr 19, 2013 | 05:15 AM
  #830
scottsjeeprolet's Avatar
IT seems that everyone has gone their separate ways and moved on. Too bad, we had some good times together.
I'll try this summer and do something. Maybe a wrenchin day with a bonfire.
Old Apr 28, 2013 | 01:42 AM
  #831
bigsingle's Avatar
When my pulling truck is back and closer to being in one piece I'll have a get together at my place. Right now its in a few hundred pieces and spread all over my shop.
Old May 7, 2013 | 04:16 PM
  #832
Random MAP codes from computer. MAP has been replaced. Next? Unplug the Comp and see if it continues? I assume I can just unplug the MAP and turn off the box for testing?
Old May 10, 2013 | 11:25 AM
  #833
bigsingle's Avatar
Remove the comp's MAP connection, but make sure you plug the factory harness back into the MAP or you will have 0psi boost and no power (ECM sees no boost and cuts back fuel, i've done this before )
If the MAP is new and the code still shows up, then I would think you are correct in that something is faulty in the comp or its harness when its sending the signal to the ECM.
Old May 20, 2013 | 02:42 PM
  #834
Well the boat ain't ready for the weekend so I'm headed to the Buck for the demolition derby!! Haven't been there in quite a while. Going old style - Saturday AM and leaving Sunday AM. My uncle is heading up too - should be a good time!
Old May 20, 2013 | 08:40 PM
  #835
I should be able to do that soon. I'm in Colorado right now picking my new to me 36' Montana fifth wheel. Dad gave it to me, just had to drive 1700 miles to get it one way.
Old Aug 14, 2013 | 02:27 PM
  #836
md-rebel's Avatar
I'd be up for it. be good to see some folks.
Scott I might be needing some injector info, Keene pointing me that way. Truck and trailer covered in blowby on trip, when towing.
Old Oct 16, 2013 | 12:20 PM
  #837
Still around. Had to do the contacts in the starter this past weekend. My daughter has been driving it and went up the Buck for the final event. Once it was a bit warm from towing the starter was clicking. So I didn't wait.
Man that top bolt on the starter was trouble! Tiny little bolt but being in there for 12 years I guess was hard to break loose. Sucks being old and arthritic!
Oh well - done now and running well. MAP issues seem to have gone away after thorough cleaning of the contacts.
Oh - also had to put a screw and washer in the top hole of my passenger door panel as the plastic broke. Painted it with left over gauge pod paint.
Still proud of my old truck! Have a buddy getting ready to buy a 2013 so I'll have to learn them now I guess. Yaaaa DEF!!!
Old Oct 17, 2013 | 09:33 PM
  #838
Crabjoe's Avatar
Me... I'm back in the Cummins family... Got my new truck over the weekend... This time, it's a 3500!
Old Jan 13, 2014 | 12:29 PM
  #839
lukedaemon's Avatar
@Crabjoe Nice truck!
I am still around... just working a lot and spend time with the family.
Would be nice to see folks again.
Peace.
Old Jan 13, 2014 | 07:35 PM
  #840
Crabjoe's Avatar
Peace.
Thanks!!
And now that I'm back in a Cummins, I'd love to meet up with others!!
