MD Chapter #33 Never Ending Thread X
Got my Raptor 150 Installed tonight! Pretty stout pump. Waiting on some fittings to install the rest of the 1/2" Lines from the pump forward to the inj pump.
What are you guys setting your pressures to?
For now I set mine to 22-23psi at idle and 15ish-psi at WOT.
Rick
Rick
dang that's why i like my walbro 392 pump i have it set at 20psi and it stays at 20psi even at wide open i might see it hit 19psi ever once in a while. i need to get my mitusa pump hooked back up and run it. nothing like a mechanical fuel pump with a electric back up pump.
That is where my Raptor is set to. I figure as long as it is always bypassing some fuel (14psi is where the VP44 bypasses) then it is getting enough to stay cool and happy. It worked until 125k on the 1st VP44, hopefully it will work for another 125k on the 2nd one!
My AD100 is 17psi idle and can't pull it under 15psi Wot.
So talked to Todd today, he's going to get a cab and doors and fix the truck. So i guess i gotta put it back together. Leonard we'll need that trans back soon.
hey I have that gasket if you still need it just PM me your address and I will mail it out.
Well I'm not going up tp PA today. Got some more small stuff to do then I might throw in the Mach 3's. Then work on Todd's truck. Also gotta put a new starter in the YJ and batteries in the CJ.
I'm beginning to think mine is getting old at 1.5 years. I spoke to Pureflow and they said clean out the intake screen. I spent time yesterday cleaning it out (it had a lot of grit in it). Put it back together and 19lbs at idle but she still drops to 12lbs at WOT. Guess I'll just keep watching until it drops more then call Pureflow back.
[IMG]dieseltruckresource.com[/IMG]
I have this plow Im trying to sell locally only(thats why its not in the classified section)...its in great shape and only used one season.
PM me for details...Thanks
Oh well, the picture didnt come up...its a meyer 7.5 power angling plow...everything s there except the part that mounts to the truck.
