Help with an alarm install
Old Jan 28, 2011 | 06:45 PM
DodgeMonkey's Avatar
I am in need of some dire help guys. I am attempting to install a Clifford 50.7x alarm in my truck, and have run into a snag. I have everything working, parking lights flash, remote start works, turbo timer works, everything but the door locks. The door lock circuit on the alarm is designed for cars that already have a relay in the system, which isn't the case with our old trucks. I went out and got two 30A relays for the lock, and unlock circuits, and wired them up according to the alarm and FSM wiring diagrams. My problem is that the door locks seem to be drawing a metric sheet ton of current. They blow 30A fuses no problem when you try to activate them with the alarm, and if you go straight to the battery, they won't lock or unlock. They click and move a hair, but will not pop up or down all the way, and they draw enough current to dim the dome lamp. Has anybody run into this before? I assure you my wiring is up to the task, the relays are all run with 10ga wire, which is larger than the factory wiring, and all connections are soldered.
Old Jan 28, 2011 | 06:59 PM
I just found out that the circut is -/+ switching on both the unlock and lock circuts. How do I wire that up? I am completely stumped here.
Old Jan 28, 2011 | 07:28 PM
truckwrench1's Avatar
it sounds like you will need 4 relays and some 1 way diodes but not shure of the wireing but you will have to apply power with 1 relay and ground with the other so 2 relays for 1 door lock both with diodes so it will not back feed WOW my head allready hurts on this
Old Jan 28, 2011 | 07:34 PM
ya mine too. I may just take it somewhere and pay to have the door locks done.
Old Jan 28, 2011 | 07:39 PM
i have a guy i work with that is awsome with stuff like this if you would like i can ask him and get back to you but i will not see him till tuesday
Old Jan 29, 2011 | 11:24 AM
Dean Snow's Avatar
let me get u the diagram. i just did this. you will only need to relays
may take me a few. but ill get it to you
Old Jan 29, 2011 | 11:46 AM
Dean Snow's Avatar
I just uploaded the pictures. As soon as theyre approved ill like them to this thread. Theyre not the best since i had to take a picture of a piece of paper since I dont have a scanner but they will work.
Old Jan 29, 2011 | 03:19 PM
That would be awesome! Thanks!
Old Jan 31, 2011 | 12:05 PM
Any luck with those pics?
Old Feb 2, 2011 | 11:28 PM
Dean Snow's Avatar
hey. sorry this took so long. i uploaded them the same day but havent been back on since.
93bomber
Feb 28, 2011 02:01 AM
Katman
20
Jan 5, 2009 10:45 AM
2500CTD
Dec 17, 2007 04:48 PM
Txwelder
Jan 12, 2006 08:54 AM
SCClockDr
Jan 2, 2006 07:55 PM
