Help with an alarm install
I am in need of some dire help guys. I am attempting to install a Clifford 50.7x alarm in my truck, and have run into a snag. I have everything working, parking lights flash, remote start works, turbo timer works, everything but the door locks. The door lock circuit on the alarm is designed for cars that already have a relay in the system, which isn't the case with our old trucks. I went out and got two 30A relays for the lock, and unlock circuits, and wired them up according to the alarm and FSM wiring diagrams. My problem is that the door locks seem to be drawing a metric sheet ton of current. They blow 30A fuses no problem when you try to activate them with the alarm, and if you go straight to the battery, they won't lock or unlock. They click and move a hair, but will not pop up or down all the way, and they draw enough current to dim the dome lamp. Has anybody run into this before? I assure you my wiring is up to the task, the relays are all run with 10ga wire, which is larger than the factory wiring, and all connections are soldered.
it sounds like you will need 4 relays and some 1 way diodes but not shure of the wireing but you will have to apply power with 1 relay and ground with the other so 2 relays for 1 door lock both with diodes so it will not back feed WOW my head allready hurts on this
I just uploaded the pictures. As soon as theyre approved ill like them to this thread. Theyre not the best since i had to take a picture of a piece of paper since I dont have a scanner but they will work.
Katman
20
Jan 5, 2009 10:45 AM
Txwelder
Jan 12, 2006 08:54 AM
SCClockDr
Jan 2, 2006 07:55 PM
