Brake Lights.
Old Feb 2, 2011 | 05:45 PM
TrkEnvy's Avatar
Brake Lights.
I just installed a new brake booster and master cylinder unit. My dad and I bled the brakes, but we have a problem. My brake lights are on and will not go off. What did we do? How does the brake lights work and how can we fix it??
Thanks
Old Feb 2, 2011 | 06:03 PM
dieselcrazyw350's Avatar
look under your dash at your brake light sensor. its a common problem for them to get pushed back too far to where the brake pedal wont push the little rod in.
Old Feb 2, 2011 | 07:40 PM
92betsy's Avatar
I've had my sensor zip-tied for about 3 years now just tightened it to the bracket.
Old Feb 2, 2011 | 09:27 PM
autocar56's Avatar
I have the same problem, installed a reman brake booster and master cylinder, reset the brake light switch. reach under the pedal and pull up, it will pop out the switch. Never had that problem before, I am wondering if their is something wrong with the brake booster that the pedal rod would come out that far. Since it has a lifetime warranty I'll probably take it back to compare.
Steven M
Old Feb 2, 2011 | 11:00 PM
TrkEnvy's Avatar
Got her fixed.. The bracket moved and she is working good now. Thanks!! I have a little bit different question now. Before the brakes were soft and came up smooth. Now its soft for the first 1/4 in of movement then they come on like a ton of bricks. Very jerky if I am not linear with it. Can I adjust something to fix this?
Old Feb 2, 2011 | 11:34 PM
Dean Snow's Avatar
i would say your other booster was just junk. my brakes work as you described....until i hook a trailer up. then i use more travel. as soon as my foot is on the pedal my brakes are being applied. i like them like that though
polaris800sp
Nov 13, 2008 05:35 PM
jj3500
Jul 5, 2008 11:20 AM
CHarlan
Aug 6, 2003 08:40 PM
