wont start
Old Apr 29, 2008 | 10:54 PM
LRTX's Avatar
wont start
98 24 valve code reader said injector pump timing failure more than 5 seconds how do you fix this? will start with starting fluid
THanks
Old Apr 30, 2008 | 10:20 PM
PChouinard's Avatar
See what happens when that starting fluid hits the grid heaters if they're on..
What exactly is your problem? Be specific and you will get a direct answer..
Old May 1, 2008 | 07:35 AM
j-fox's Avatar
How much( or how little) is the fuel pressure? Is there any fuel leaks?
Possible VP-44 failure.
Old May 1, 2008 | 07:48 AM
John Faughn's Avatar
Give your location , someone may be in your area .
Check lift pump pressure , the main pump in those trucks can make the truck start & run , but that ends up killing the pump over time .
But again specific facts , what code number ?
The main problem with starting fluid is if the grid heater is operating when you spray [ BANG ] , disconnect the grid heater relay , and spray very little starting fluid .
Old May 1, 2008 | 02:52 PM
REF>Lancer's Avatar
THanks
Had the same code when I started the truck after I put an engine in it,if you are low on fuel could be you are suckin air.
try replacing that little valve on the return banjo,if that don't fix it I'd bet it's you VP.
rustydeeretech
Jun 16, 2010 09:41 AM
CoolumConst
Oct 11, 2008 10:00 PM
Stroked-Z
Oct 4, 2008 11:28 AM
qcstunter
Jan 9, 2007 04:10 PM
Desert Diesel
Dec 5, 2002 08:53 PM
