wild steering o.d. in and out
Old Jul 2, 2003 | 11:18 AM
I8HTBMPS2000's Avatar
i have a 92 dogde w250 I have a little steerig problem when i am going down the road the truck goes back and forth and when i make a turn thr truck will be turning fine and then it will jolt off in the same direction. i also have a problem with my overdrive kicking in and out and seen were you can hook your over drive up on a toggle does this work good.
Old Jul 2, 2003 | 02:33 PM
docwes's Avatar
Re:wild steering o.d. in and out
Your steering problem is probably a worn out idler arm, quite common problem. The shifting problem can be fixed for about 2 cents with a cotter pin and 20 min of your time with a volt meter. I will try and post pics soon. Any good front end shop should be able to help with your steering. Good luck.
Old Jul 2, 2003 | 10:27 PM
jdeereboy's Avatar
Check the steering box mounting bracket. It is common for this bracket to come loose as it is held with only 3 bolts. I tack welded the bracket to the frame on my '84 Sno Commander.
FiverBob
Aug 17, 2013 11:43 PM
Justwannabeme
Feb 12, 2008 01:08 PM
chrigu
Jul 17, 2007 05:47 PM
dodgeguy71
Jan 9, 2007 05:37 AM
dodgezilla04
22
Dec 29, 2006 06:26 PM
